Old 07-20-2011, 10:39 PM   #6
ford1
Default Re: OPEN PLENUM 4 BARREL INTAKE GOOD?Bruce?
open plenum manifolds are designed to produce max h/p at high rpms, they usually dont start producing power till around 2500 rpm all the way to 5000 or more rpm, not good for low end torque, if you want to use a 4 barrel manifold get a dual plane one
ford1 is offline   Reply With Quote
