Just wondered if there is any confirmed way of which position the hubcaps go on the wheels.
Bottom of the V pointing at the valve stems or the opposite way round? |
I would doubt that Ford workers would look at how the hubcap was placed on a wheel going by an assembly line.
I have a 36 Ford 5W Coupe and I did locate the hubcaps with the point of the V8 pointing towards the valve stem, just my opinion. |
Ha, Ha, I thought I was the only silly bugger that pointed the pointy end of the V8 of the hubcap to the valve stem. A good reason for this is that it makes it quicker to find the valve stem when checking your tyres. Regards, Kevin.
This makes about as much sense as aligning screw slots all in one direction, a practice possibly having its roots in the AACA judging camp.
Alan |
Frank Lloyd Wright purposely aligned screw heads in some of his builds as a design element.
#7 | |
As an aside, I once lost an original oval head screw in my driveway, which almost brought tears. Two days later, I celebrated finding it with a stiff shot of bourbon and a beer chaser! I didn't feel silly at all, just a little tipsy!
Alan |
My dad was a builder and owned a 1946 Ford Deluxe Sedan. He kept his tools in the boot, and on wet days, when he opened the boot lid, rain would stream in. His solution was to add an Aluminium Strip to prevent water entering when the boot lid was open. Check out the alignment of every screw. He was a perfectionist. |
I have my own tire machine and balancer, so I always line up the tires name with the valve stem. Then I line the hubcap up with that too. I figure why not; it doesn't cost a thing. My dad used to do that when he was restoring Model A's, I'm just carrying on the tradition.
Yes, I do it too (when I remember).
Tyre brand aligned with valve hole. Hubcap aligned with valve hole, but I align the top of the V8 with the valve. I try and do it with screw heads. Traditionally (as illustrated above) it was a sign of craftmanship. Mart. |
As for tire positioning on the wheel, I clock the tire’s heavy side to the wheel’s light side, thereby reducing the need for wheel balancing weights. It’s extra labor, but I hate those ugly lead weights.
Alan |
I have a friend on the mainland that recently restored a WW2 White half track. He pointed out that the hundreds of slotted screws holding on the armor plating were specified to have the slots aligned vertically. The reason was that water/dew droplets would drain off more readily, lessening the chance of the vehicle 'glistening' in a distant nazi spy glass.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#13 | |
Alan |
#14 |
Can´t be done if there is not a nut on the other end but a threaded part.
#15 |
I walked completely around it and teased him because I couldn't detect any at 89 or 91 degrees to the horizon. Perhaps he had a huge box of 1/4-20 flat head slotted machine screws to keep trying til he got it. The guy is the military vehicle collectors version of our 'Kube'.....
#16 |
Well things certainly strayed off the subject with this question but still good answers.
#17 |
I believe it is not unknown when in a studio photographic session to jack each wheel up so it can be rotated to be the right way up and let down again.
#18 |
I saw a car at a show with all the wheels positioned with valve stems up and hub caps aligned. So i mentioned it to the owner who laughed at me and said, huh, that's just the way I drove it in.
#19 |
Off subject but many electricians align switch and outlet plates screws!
#20 |
I had Halftracks, The story about having the screw heads clocked correctly is widely known to anyone rebuilding one. Pretty much all the visible armor screws are oval head 3/8 fine with nuts on the inside.
And there are hundreds of em! Last edited by cas3; 11-22-2025 at 10:19 AM. |
