Old 11-02-2025, 08:53 PM   #1
Nickoman
Default Clutch diameter question
Howdy I have a 41 Ford tudor with a 221 and a side loader transmission. Seems to be a funny year for parts/ standards. Would anyone know the size of clutch it would have. 10", 11" or 9? Trying to get parts ordered before I slide the trans and rear end out of the car to make it a quicker swap. Thanks in advance
Nickoman is offline   Reply With Quote
Old 11-02-2025, 09:19 PM   #2
big deuce
big deuce's Avatar
Default Re: Clutch diameter question
My best guess would be 9". There are a lot of not so good pressure plates out there, get your parts from Mac Vanpelt Ford parts.
big deuce is offline   Reply With Quote
Old 11-02-2025, 09:27 PM   #3
tubman
tubman's Avatar
After 84 years, the only way to be absolutely sure is to take it apart and measure it.
Old 11-02-2025, 09:38 PM   #4
big deuce
big deuce's Avatar
That flywheel has the raised lip, with the pp bolts near the shoulder like my 9".
There would be an extra set of springs in the area of the red circle if it were 10 or 11"
Old 11-02-2025, 09:51 PM   #5
Kube
Super Moderator
Kube's Avatar
Looks to be a 9".
Kube is online now   Reply With Quote
Old 11-02-2025, 10:58 PM   #6
cas3
I agree with the Deuce, at one glance you can tell the disk size by how many springs it has. Two on each of the ....What you call it...3 sections, will be a 9", three will be a 10 or 11
Old 11-02-2025, 11:39 PM   #7
petehoovie
petehoovie's Avatar
Old 11-03-2025, 07:47 AM   #8
Terry,OH
Terry,OH's Avatar
If you could rotate the PP and look for a part number if found you would be in luck.
Old 11-03-2025, 08:26 AM   #9
Nickoman
Thanks everyone, Gonna crank it over after work and check it out. I had a 46 merc as a kid in high school and that seemed a lot more standard. 41 seems to have a lot of weird changeovers through production
Old 11-04-2025, 05:57 PM   #10
Mart
Mart's Avatar
It's a 9". The flywheel with the raised heavy rim only accepts a 9" clutch.
Old 11-07-2025, 03:01 AM   #11
fortyonerag
fortyonerag's Avatar
You're not alone, seems there are many changes across the 41 year. Never a dull moment.
fortyonerag is offline   Reply With Quote
