Old 10-15-2025, 04:24 PM   #1
tcom
Default Front seat removal 1946 Ford convertible.
Good afternoon,
I want to have the front seat cushion rebuilt. How does it come out? Do I have to remove the entire seat or or does it come out the same way the back seat cushion does? I know there are old threads on the subject. I tried the search function but none were displayed.
Additionally The convertible top will not come up. Two men swearing mighty oaths can get it up and latched. The motor works and I can hear the pump. It will come up a little then drift down when I release the switch. First step is to check hydraulic fluid.
I believe that the rear seat cushion comes out by pushing the cushion back and lifting the front, exposing tabs that hold the back, so I can get at the reservoir, correct?
Thanks,
tony
tcom is offline   Reply With Quote
