Old 10-12-2025, 06:58 PM   #21
40cpe
40cpe's Avatar
Default Re: Rear hub removal blues
Originally Posted by Kurt in NJ View Post
Always jack up the other side wheel off the ground
Both rear wheels are on jackstands.
I have tension on it so the tool is just starting to bend. I'll leave it until tomorrow. If it doesn't give up, I'll add a modest amount of heat.
I've bought the tool from the ad on EV8, but I have to send the money and then get it shiopped here. It will be a while.
Old 10-12-2025, 08:07 PM   #22
ford38v8
ford38v8's Avatar
The above advice would apply if using an impact method, but has no benefit with a KRW type tool. Proper method would require no more than a rap with a
Hammer, if at all.
With regard to the tool’s axle nut, the instruction to back off by ½ thread doesn’t make sense to me. In my opinion (I’ve used this method many times), the threads should not be put at risk of distortion, rather, should accept equal pressure with the axle’s end, which would be at the point of initial contact, not even finger tight.
Alan
Old 10-13-2025, 07:11 AM   #23
rich b
rich b's Avatar
For the axle nut; I welded a round piece of 1/4 steel to a 5/8-18 nut. Run it up snug on the axle threads so the puller bolt acts on the end of the axle, not the threads.
Not mine in the picture; but the same idea.
Old 10-13-2025, 10:30 AM   #24
petehoovie
petehoovie's Avatar
Old 10-13-2025, 10:59 AM   #25
19Fordy
19Fordy's Avatar
Zeke 3's suggestion is the best. Avoids and chance of thread damage.
Old 10-13-2025, 03:07 PM   #26
Charlie Stephens
Check with your local club and see if they have a puller to loan.
Charlie Stephens
Old 10-13-2025, 03:11 PM   #27
40cpe
40cpe's Avatar
Well, I got it off without breaking anything. For inquiring minds, I'll tell you what worked for me. I put the puller back on the hub with the bent part turned inwards. I tightened it until the bent part was back straight again and left it overnight. It was still tight today, so I removed it and used an 8# sledge hammer to back up a 2# hammer and struck the tapered area of the hub all around. I put the puller back on and tightened it until it started to bend. One lick on the puller boss at the axle end and it popped loose.
Thank you all for your helpful comments. I have ordered the Vintage Precision puller for the next time.
Old 10-13-2025, 03:54 PM   #28
Mart
Mart's Avatar
This thread (not that type of thread) shows a bent axle thread. I wonder if it was caused by a poor or incorrect puller?
https://www.fordbarn.com/forum/showthread.php?t=353107
Mart is online now   Reply With Quote
Old 10-13-2025, 10:13 PM   #29
New2restoring
I purchased a hub tool from 3rd generation, and it worked just fine.
New2restoring is offline   Reply With Quote
Old 10-14-2025, 12:40 AM   #30
ford38v8
ford38v8's Avatar
With all due respect to Michael, his Economy Hub Puller, in my opinion, looks to be very sensitive to position correctly without experiencing bad results. The KRW type on the other hand, is all but fail-safe. I may be wrong in my opinion, but then, I always went for the best that money could buy.
Alan
Old 10-14-2025, 04:33 PM   #31
Tim Ayers
The Vintage Precision tool should be in every Early Ford owner's tool box or a good friend's tool box. It is very, very well made and I have not encountered a drum it will not remove. Highly recommended
Old 10-14-2025, 09:18 PM   #32
40cpe
40cpe's Avatar
Thanks for sharing your experience with it. I hope my experience is like yours.
Old 10-14-2025, 10:23 PM   #33
Bored&Stroked
Bored&Stroked's Avatar
If I was having this issue, I'd use some heat all around the tapered area of the hub (like a good map torch) - my bet is that the expansion would make the pulling a lot easier.
Old 10-15-2025, 05:12 AM   #34
glennpm
glennpm's Avatar
Second that
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 10-15-2025, 07:37 AM   #35
Bruce of MN
Bruce of MN's Avatar
Not arguing, but why?
Old 10-15-2025, 10:26 AM   #36
cas3
Because it provides a little slack in the assembly so the force of the hit does not stop when the axle gear crashes into the spider gears
