Here is a picture of a Multi-disk flywheel from a RHD car. I took it apart because the clutch was stuck. I believe that the problem was due to ware on the splines. Is this flywheel now a boat anchor?
I lived with one worse than that for many years but eventually converted the car to single plate ... Are RHD single clutch bell housing available stateside or are you going to have to import one if you change?
It could be repaired but it will take a lot of welding and machining to restore the splines.Those were a one year only item and many were changed over to the single disk type but it takes a lot more than just a flywheel and a clutch. The bell housing and transmission are different as well. A lot depends on how authentic a person wants it to be. There is also the problem of having the Able type starter drive. It was made to work with that old splined flywheel but they aren't reproduced either.
We've had discussions about this before. Another alternative is to used a later flywheel modified to have a machined spline adapter bolted up to it. Someone made one years ago and there are photos of it in the archives if searched. A set up like this might work with the later Bendix starter drive. This is a link: https://www.fordbarn.com/forum/showt...+disk+flywheel Last edited by rotorwrench; 10-10-2025 at 11:17 AM. |
Too bad you cannot make the engine run in reverse and flip the differential over.
#5 | |
I once had a reverse running Corvair engine (reverse ground cam) we put into a VW Tybe 2 Kombi mated to the VW transmission. Hauled A$$.
The Master Cylinder Enjoying life at the beach in SoCal... |
And - along the same lines - simply clean it out and try a "keep on going" attitude? I've recently seen SEVERAL "clutch paks" for the multidisk - one was NOS which would be the disks of choice. Joe K
Shudda kept the horse. |
I have replaced the clutch with a single disk clutch. I do not want to take a chance that it will lock up again and I will have to remove it to fix it.
Bob |
