#28 |
I helped a local club member with similar issues on her 41 pickup that had been converted to 12V. She was running a Bosch blue coil that would get hot and break down. I ended up using a Standard Motor Products UC12 coil with an external resistor mounted on the coil bracket, that solved the coil break down issue.
