Old 09-01-2025, 02:09 PM   #1
rustynut4247
rustynut4247's Avatar
Default 47coe
which is correct pos or neg ground or does make any difference ? also does the volt regulater pos or neg ground and i have a parasite draw someplace
rustynut4247 is offline   Reply With Quote
Old 09-01-2025, 02:17 PM   #2
38 coupe
38 coupe's Avatar
Default Re: 47coe
I'm not 100% sure what your question is, so my response is a bit generalized.
The original 6V system is positive ground. It matters for your generator & regulator, and for ignition system efficiency (spark jumps easier one way than the other when hotter ground vs colder ground). Everything else will work pretty much the same.
Most 12V conversions use negative ground. Again the generator & regulator (or alternator, whatever) will care which is ground, and ignition efficiency is better when the proper side of the coil is ground. Any modern electronics will probably care.
