Old 04-12-2018, 06:57 PM   #1
JD
Default 1933-34 Ford pickup dash light
Can anybody tell me where the dash light bulb is fitted on a 1933-34 pickup? I can't find a housing on the back of the dash.
JD is offline   Reply With Quote
Old 04-12-2018, 07:31 PM   #2
DavidG
DavidG's Avatar
Default Re: 1933-34 Ford pickup dash light
Above the speedometer; there should be a bracket to insert the bulb socket and wire assembly.
Old 04-12-2018, 08:07 PM   #3
totto
totto's Avatar
Just what Dave said. That is what I have on my "34.
Henry
totto is offline   Reply With Quote
Old 04-13-2018, 02:30 PM   #4
2ndgeer
2ndgeer's Avatar
Here's a picture of the dash light bracket. It attaches behind the dashboard with the central screw the holds the dash board.
2ndgeer is offline   Reply With Quote
Old 04-13-2018, 02:31 PM   #5
2ndgeer
2ndgeer's Avatar
Here's a picture of the dash light bracket. It attaches behind the dashboard with the central screw that holds the dash board.
Old 04-13-2018, 02:32 PM   #6
2ndgeer
2ndgeer's Avatar
Oops!
Old 04-13-2018, 07:51 PM   #7
JD
I figured the housing bracket must mount behind the central dash screw, following the reply from David G. I didn't have the bracket itself when posting the question but I have since located it among my parts and it all make sense now. Thanks for the help!
Old 08-14-2025, 07:47 PM   #8
Fixin32
Hello, Would you happen to know the part number for the bracket and light? I have 46 13727 but not sure if its correct. It came out of a 1933 Model BB pickup truck
Fixin32 is offline   Reply With Quote
Old 08-14-2025, 08:09 PM   #9
Newc
Newc's Avatar
I posted one such bracket For Sale. The switch and lamp are reproduced. It must ground to the dash and the dash must then ground for complete circuit, no pads behind the dash screws. Newc
Old 08-15-2025, 09:15 AM   #10
Tim Brown
Tim Brown's Avatar
I have 2 extra mounts if anyone is looking for one send me a message. Tim
Tim Brown is offline   Reply With Quote
