Old 08-10-2025, 11:50 AM   #1
Chibears
Default 1940 ford deluxe radio
How do you get power to radio from harness or switch
Chibears is offline   Reply With Quote
Old 08-10-2025, 12:09 PM   #2
HDowse
HDowse's Avatar
Default Re: 1940 ford deluxe radio
My 1940 radio is wired to the firewall block where the ignition resistor and circuit breaker is located. It’s wired to the far right post which is the hot side of the circuit breaker. The wire to the radio has an inline fuse.
HDowse is offline   Reply With Quote
Old 08-10-2025, 06:42 PM   #3
Chibears
Thank you HD! Will follow that advice and see if I have some tunes!!
Old 08-10-2025, 07:22 PM   #4
tubman
tubman's Avatar
Maybe no tunes, but you will get crop reports or Spanish programming depending on where you are.
Seriously, the last decent AM station up here (North-Central Minnesota) disappeared about 15 years ago.
Old 08-10-2025, 08:01 PM   #5
hueyhoolihan
ha, maybe THAT's the reason a couple of my 2007 model cars with otherwise excellent sound systems were so terrible when trying to tune in an AM station. and i thought it was because the manufacturers were on some kind of cost-cutting crusade! smh.
hueyhoolihan is offline   Reply With Quote
Old 08-10-2025, 09:52 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
The power wire gets attached to the left terminal on the circuit breaker underneath the dash.
Old 08-12-2025, 06:04 PM   #7
Kube
Super Moderator
Kube's Avatar
Spot on Ken.
Guys, this is correct.
Old 08-12-2025, 06:17 PM   #8
hueyhoolihan
i suppose one could connect it to get power when the ignition switch is on or off depending on where one chooses to connect it to the fuse/breaker box. where it was in 1940 IDK. i'd have to guess it was dependent on the ignition switch being in the "on" position. seeing as how radios at that time had power hungry tubes in them. not that that in and of itself would be of much benefit unless the engine was running.
in any case i clearly remember (because my dad was furious) completely running down the battery while listening to the radio (tubes) for a couple of hours in our 1961 Buick LeSabre for "Wild Thing" (the Trogs) and "Li'l Red Riding Hood" (Sam the Sham and the Pharaohs) to be played.
it probably makes little functional difference with the solid state radios of today.
Old 08-13-2025, 07:47 AM   #9
Terry,OH
Terry,OH's Avatar
The ON/OFF switch is part of the dial. Rotate the volume control and it should click. The Std. and Dlx. cars used the same radios. There are two different Mfg. Philco and Zenith.
Old 08-13-2025, 10:48 AM   #10
mcgarrett
Unless your radio has undergone some repairs in the recent past, I doubt you'll hear anything. The radio in my '40 used to work, but now I'm lucky if I can even get the vibrator to humm.
Old 08-13-2025, 02:40 PM   #11
Chris in MA
Chris in MA's Avatar
The radio in my 40 only gets Gunsmoke and Amos and Andy.
Chris in MA is offline   Reply With Quote
