#21 |
That sedan delivery just found a good home.
#22 |
Sedan deliveries are cool. With all the stuff that my wife packs for a tour along with the stuff for the pooch I think I now need one!
#23 |
#24 | |
However, this one appears so nice that it would even convert me. I'm sure whatever Mike decides to do with it, it'll turn out great! |
#25 | |
Super Moderator
![]() A pair of NOS outer mirrors came with the delivery. I need to remove the hinge pins. Any of us that have done that know it's a task worth putting off.
#26 | |
I have wondered if Kube has a special way of finding vehicles or if they have a special way of finding him!!!!!!! LOL Last edited by 34fordy; 08-07-2025 at 03:23 PM. Reason: spelling |
#27 | |
Super Moderator
Thanks for that smile ![]() Just came in from removing the front clip. I'll pull the heads and intake and take a look inside that engine. Fingers crossed ...
#28 |
Amazing find job well done!
You have all of the upcoming winter to work on it ![]() Super neat '36 love it! |
#29 |
Hey - the dark side is not so bad! Just think of all the time and money you save in leaving them in their patina’d beauty! AND you can park it anywhere you want at cruise night and watch everyone come to check out your car vs the nice shiny version ones all around you!
#30 |
We have all heard of a 1936 Ford Town Car, the closed car with the area over the driver open. On that basis, this example must be a 1936 Ford Town Delivery. |
#31 | |
Looks like I amgonna welcome you into the 12,000 club LOL. Is this a factory made vehicle or a custom job? |
#32 |
I think that one is used to carry someone to their final destination!
#33 |
#34 |
Super Moderator
Ya know guys, a large part of the enjoyment I get from these cars is attempting to figure the history of each the best I am able.
This delivery is already proving to be a mystery. I am 99% certain this car sat since 1964. So, I have just removed the cylinder heads and intake. There is a very small amount of carbon on the top of the valves and at the very top of each cylinder. So little on the cylinders, I was able to easily wipe it away with a scrubby pad. The heads came off literally in less than 15 minutes. Engine is .060" over bore. Extremely clean in the valley. Turns over by hand very nicely with just the "feel" I desire. So, why would someone rebuild and install an engine, hardly drive it and place the car in storage? Oh, odometer shows 34k, oil sticker shows 33k. Any theories?
#35 |
To me, it seems odd that the motor would require a rebuild after thirty thousand miles.
Tom |
#36 |
Rebuild at 30,000 miles was common in the 1930s. The roads were mostly dirt and gravel so lots of dust to tear up the rings and cylinder walls, the lubricants were crude compared to modern oils, and no there was no oil filter on the engine. Engines wore out before the car did. One of Ford's advertised selling points was their engine exchange program, get a factory reconditioned engine installed in your car in one day instead of whatever quality and time it took a local shop to go through your worn out engine.
One possibility for why the car got a rebuilt engine and was parked is the same as some projects today: the owner was older and fixing up a car that was special to him, but health issues got to him before he could drive and enjoy his labor. |
#37 | |
Super Moderator
Also, I agree 100% as to how quickly engines wore outback then. Even as late as the early / mid 60's, it was not unusual to rebuild an engine at 75k. Valve job? 40k. I think many folks forget just how poorly things were built / designed, etc. back then vs. today.
#38 |
Being a delivery it may have had lots and lots of short journeys. Hence accelerating the wear at relatively low mileage.
From what you've found it seems like it will respond to a sympathetic recommissioning. I await further progress with interest. |
#39 | |
#40 |
I wonder if it was used as a commercial vehicle as intended, could be while the motor was being rebuilt, the business realized that their "replacement" truck was better suited for the particular job at hand and kept using the new one, so this old girl got demoted until the new owner bought out. We all know what happens to old projects full of good intentions.
