Old 08-10-2025, 09:57 PM   #1
kimbercarrier
Default 1940 Ford truck tire/wheel options
Can any of you that have 40/41 pickups please post pictures of your ride.
Please also include the tire and wheel size (including backspace) and any suspension drop/mods you've done.
Looking to order my wheels and tires, and I'd like to see what others are running!
Thanks!
kimbercarrier is offline   Reply With Quote
Old 08-11-2025, 10:26 AM   #2
TJ
TJ's Avatar
Default Re: 1940 Ford truck tire/wheel options
Is your pickup a stock pickup or a modified pickup with later running gear? Modern rear end and modern front end(Mustang II or dropped axle)? If modified go to the Wheelsmith website and they have a complete diagram how to do the measurements. WWW.Wheelsmith.net. The diagram will work for a stock pickup or a modified pickup.
Old 08-11-2025, 01:52 PM   #3
Zeke3
Zeke3's Avatar
Try www.thewheelsmith.net.
Zeke3 is offline   Reply With Quote
Old 08-11-2025, 02:02 PM   #4
TJ
TJ's Avatar
Zeke, thanks. I forgot to add "the" which make a big difference.
Old 08-11-2025, 02:18 PM   #5
Zeke3
Zeke3's Avatar
TJ you are welcome.
Old 08-11-2025, 02:43 PM   #6
kimbercarrier
My truck Is using stock running gear. I removed a leaf from the front and swapped 2 from top to bottom of the pack in the rear.
What is the original rim size? ( I think 16x4) and what is the backspacing on the original rim?
Old 08-14-2025, 04:43 AM   #7
38 coupe
38 coupe's Avatar
I use the stock wheels and hubcaps, they look good. If you want your truck to look like a truck then run 6.50-16 bias ply or 215/85-16 radials black wall tires.
