Old 08-05-2025, 05:14 PM   #1
s.e.charles
s.e.charles's Avatar
Default exhaust to intake manifold pipe - plumbing method request
reading California Bill's Ford Speed Manual - 1952 edition - page 40 makes the statement: "A low manifold with heat is more attractive ..."
so my question du jour .. . . . how was the piping run from the exhaust manifold to the intake manifold. was the exhaust gas desirable to run through an intake? are the chambers of an intake manifold such that the exhaust gas was isolated from the combustion air being run through the carburetor(s)? and then, how do the exhaust gases exhaust?
no; i've not read the entire book, and perhaps there will be more told as it goes on, but i wanted to get a place marker for my subsequent questions since my 'search' under the above title left me unsatiated.
thanks,
sid
s.e.charles is offline   Reply With Quote
Old 08-05-2025, 05:40 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: exhaust to intake manifold pipe - plumbing method request
Intake side of the block, center, are two holes, one each side. These come from the exhaust of the cylinders 2, 3 and the 6, 7 exhaust... So, no piping from ex pipes.
There are two corresponding passages in the intake manifold to a small chamber under the carburetor... No exhaust gets to the engine combustion.
Karl
Karl Wolf is offline   Reply With Quote
Old 08-06-2025, 07:02 AM   #3
s.e.charles
thanks KW. i was going from a Chevy straight 6 YT which showed a pipe from one of the split exhaust headers to the intake manifold.
appreciate the help.
s.e.
