Has anyone else seen where the in dash oil pressure gauge on a 1936 coupe is exactly 10 psi higher than a mechanical gauge which is on the same T as the oil pressure sender. The sender is new from Thirdgen.
Andy |
The sender must match the gauge. Early systems were 50 lb, late were 80 lb. Your sender should have the number 50 stamped on the unit.
Alan |
