Old 07-17-2025, 02:50 PM   #1
Vanspeed
Vanspeed's Avatar
Default 49 8BA has no power
Hi guys. Working on a ‘49 F-1 that was parked in the late 60’s. The truck starts on the first crank and idles very nicely. Upon driving it has hardly any power. It does not sputter or backfire, just no power. If the road starts to climb it is almost impossible to get up it. Truck has new gas tank, new lines, in-line filter before pump. Compression on cylinders is 100,90,90,90,100,100,90,85. I have tried two different carbs. It has a Petronix ignition in the stock disrtibutor. Owner did not want to deal with points any more. I feel like the distributor is not advancing or possibly timing is off? I would think timing off would give me some backfires or rough idle but it does not. Lack of fuel? Any suggestions appreciated.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 07-17-2025, 02:58 PM   #2
51504bat
51504bat's Avatar
Default Re: 49 8BA has no power
IIRC Pertronix systems are particular as to what coil and spark plugs wires are installed. Might be part of the problem or not. If it was me I'd replace the current distributor set up with a know good one and see if there is any improvement. JMO
Old 07-17-2025, 03:27 PM   #3
cas3
muffler plugged up?
Old 07-17-2025, 03:44 PM   #4
Vanspeed
Vanspeed's Avatar
The owner had some Fenton headers installed and new exhaust. Distributor is original and the fuel pump was the pump that was on it. I am thinking it is distributor not advancing or fuel. The distributor was not moved as it fired right up the first time we worked on it and you can tell it has not been messed with, what I mean by that is you can tell this distributor is in the exact spot it was in when new.
Old 07-17-2025, 04:02 PM   #5
ford38v8
ford38v8's Avatar
There seems to be a conflicting information here. Petronix is what you said it has, but then you say it has original ignition. Can't be both.
Alan
Old 07-17-2025, 04:09 PM   #6
hueyhoolihan
IME, retarded timing will often start and idle very well, will not backfire and lack power as RPM increases.
coincidentally, i just replaced my old distributor. i had concluded that it was failing to advance the timing properly, possibly due to binding weights.
power was lacking as the RPM increased due to misfires. the differing symptoms, yours simply lacking power, and mine misfiring, could be attributed to the richness of the mixtures between my carb and yours.....possibly.
hueyhoolihan is online now   Reply With Quote
Old 07-17-2025, 04:30 PM   #7
Vanspeed
Vanspeed's Avatar
I apologize, original distributor that has Petronix ignition installed.
Old 07-17-2025, 04:34 PM   #8
Vanspeed
Vanspeed's Avatar
The owner sent a carb to Charlie NY to rebuild and I was ready to install it when I noticed the carb he sent Charlie was an early carb, model 91-99, that doesn’t have the vacuum port and has the wrong air cleaner base so I couldn’t rule out it being a carb issue.
Old 07-17-2025, 05:09 PM   #9
ford38v8
ford38v8's Avatar
That makes sense now. An 8BA needs that vaccuum port from the carburetor. Your ignition would then be advanceing correctly with the correct vacuum port.
Alan
Old 07-17-2025, 05:35 PM   #10
tubman
tubman's Avatar
You might want to talk to Charlie again. I wouldn't be surprised if he wouldn't want to fix you up with a proper 8RT carb in exchange for the 91-99 for a reasonable charge. I think the "91-99"s are a little scarcer than the 8RT's.
Old 07-19-2025, 10:42 AM   #11
Vanspeed
Vanspeed's Avatar
Could you pass along Charlie’s email to me? I would be more than happy to swap out the 91-99 for the correct carb. Pm me if you can. Thanks.
Old 07-19-2025, 11:49 AM   #12
petehoovie
petehoovie's Avatar
[email protected]
Old 07-19-2025, 11:52 AM   #13
glennpm
glennpm's Avatar
Yup, good advice.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 07-19-2025, 12:16 PM   #14
tubman
tubman's Avatar
With the wrong carburetor, he has no advance at all. Let's see what installing the proper carburetor does before offering more advice.
Old 07-19-2025, 03:02 PM   #15
GB SISSON
GB SISSON's Avatar
Denny, I'm not sure of the wording but in post #8 it seems like he's saying it has a correct 8ba carb (with port) on it currently, but the PO had mistakenly sent an early style carb for rebuilding. So the current owner now has that Charlie NY early carb sitting on the bench and can't use it as a tester as it doesn't have the vacuum port.
Old 07-19-2025, 03:16 PM   #16
38 coupe
38 coupe's Avatar
I have seen earlier carburetors installed on 8BAs with the vacuum advance tied into manifold vacuum. That results in the opposite of the advance curve you want.
Make sure your vacuum advance is good. Then use the correct carburetor with the advance connected to the port in the carburetor center section.
Old 07-19-2025, 04:00 PM   #17
tubman
tubman's Avatar
I don't read it that way, but it really doesn't matter because my point is you can't properly troubleshoot a problem on an engine that has known problem areas. Fix them first. It looks like he's gonna get the correct carb from Charlie, which should help a lot.
Old 07-19-2025, 09:50 PM   #18
Vanspeed
Vanspeed's Avatar
Yes the engine has the correct carb on it, the owner sent Charlie an earlier version as he was not aware that the 94 changed at all. I also suspect that the mechanical advance might be seized. I am checking that on Monday.
Old 07-19-2025, 09:54 PM   #19
cadillac512
cadillac512's Avatar
The stock 8BA distributor has no mech advance. Only vac, so if it's not working you have no advance.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-20-2025, 03:56 AM   #20
hueyhoolihan
that's my understanding too.
..and Google's AI confirmed it if that's of any significance. here is how i phrased my question to Google AI: "did the original 1949 ford 8ba distributor have a mechanical advance"
here's the response: "No, the original 1949 Ford 8BA distributor did not have a mechanical advance. It was a Load-O-Matic distributor that relied solely on vacuum advance for ignition timing adjustments. This type of distributor was designed to work with the original carburetor and wouldn't perform optimally with aftermarket modifications like performance camshafts or multiple carburetors."
