Old 07-10-2025, 04:21 PM   #9
fordson
Default Re: Q: 34 Ford Coupe RHD rear window regulator
Thanks to „mercman from oz“ we found out that the position of the rear window regulator in a RHD IS THE SAME AS IN THE LHD US MODEL. The regulator was NOT switched to the opposing side. The 4-bolt Model A regulator available as reproduction can be used. I believe the crank arm needs to be modified in length for the 33/34 rear window.
Anyone with experience??
The original rear window regulator was the same for 32-34 and looked something like in the picture.
Regards Randolf
fordson is offline   Reply With Quote
