Old 07-03-2025, 12:57 PM   #1
Southtowns27
Southtowns27's Avatar
Default Won't run past 3500 rpm
I have an 8CM in my truck with about 500 miles on it since being built. It's a stock rotating assembly, bored .060" over, with a Schneider S100 cam, Isky springs, and adjustable lifters. Offy heads and intake. I clayed the engine when it was built so I know the clearances are good. It won't run up past about 3500 RPM. I can ease it up to that speed, but if I try to make it run faster it drops a few cylinders and actually slows down. I've also noticed that if I whack the throttle it also seems to drop a cylinder while it's winding up. It'll cruise down the road at 55mph no problem though. At high RPM vacuum is about 22 inches and fluctuates maybe an inch. Compression is about 125psi and they're all within 10psi of each other. Things I have tried so far: Different plugs, plug wires, different timing, condenser, swapped the Mallory dual point distributor for the stock one, it had Speedway "97's" on it, swapped those with new real Stromberg 97's (2psi fuel pressure, .043 jets, 69 power valves), reset the valve lash, different plug gaps, disconnected all the vehicle electrical and ran a jumper wire right to the coil, different coil, unhooked the wiper vacuum, unhooked the PCV system.
NO CHANGE.
What am I missing here???????
File Type: jpg 481461336_10170980117730531_5125164825946308868_n.jpg (60.1 KB, 329 views)
Southtowns27 is offline   Reply With Quote
Old 07-03-2025, 01:36 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: Won't run past 3500 rpm
Lack of fuel? Is there still 2 psi when it starts to stumble? Electric pump?
Randy in ca is offline   Reply With Quote
Old 07-03-2025, 02:12 PM   #3
petehoovie
petehoovie's Avatar
NO CHANGE.
Old 07-03-2025, 02:21 PM   #4
ford38v8
ford38v8's Avatar
THat's a beautiful engine, I bet you spend lots of time admiring that honey!
Your description of what you've tried sounds like you have a fuel issue, and from the picture, I see several possible causes:
Your high vacuum together with the small air filters suggest an air restriction. Try a temporary removal of the air filters for effect.
It takes only a very small air leak to lower your bowl level to the point of lack of fuel on acceleration. The fuel pump's glass bowl should have a cork gasket soaked in oil before careful installation. Also, check the tightness of those worm gear clamps.
The inline filter is redundant with the glass bowl, and may be clogged anyway.
Your rubber flex line may be collapsed internally. I would change out that line to a Shewman fuel resistant line, advertised in the V8 Times, without check valve.
What is not shown in the picture is your tank to firewall fuel line. Original lines being copper coated steel, they rust, flake debris, and develop pinhole leaks. Not cheap, but a Cupronickle fuel line is a great solution to many issues.
Alan
Old 07-03-2025, 02:42 PM   #5
Ggmac
Blocked exhaust ? Scratch that , you had good vacuum. What gearing and how heavy is the car ?
Old 07-03-2025, 02:46 PM   #6
john in illinois
john in illinois's Avatar
In my opinion .043 jets are too small . I have a flathead 2 carb engine in my roadster. I put an A/F gauge on it and found stock .045 to.046 worked best.
also it is impotant to check float level very carefully. that has a lot rot do with fuel mixture.
Another variable is air filters. restrictive filters can make jetting difficult.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-03-2025, 03:01 PM   #7
ford38v8
ford38v8's Avatar
John
John, I missed that. Good call on the jets.
Alan
Old 07-03-2025, 03:14 PM   #8
Tim Ayers
John
John,
I agree on both your floats and jets comments. OP- Have you checked the plugs to see if you can tell if it is leaned out?
My 292 c.i. engine with an Edelbrock Slingshot with two 97's. I had to mess with the jetting and I settled back on .046 jets and it runs strong. I tried as big as .048 and as small as .043. With .046's it runs the best.
OP- take the air filters off and see if it changes anything. If that improves it, I'd swap the Mallory back it as well.
Tim Ayers is online now   Reply With Quote
Old 07-03-2025, 04:47 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
In the picture it looks to have adjustable main jets.
Old 07-03-2025, 05:40 PM   #10
KiWinUS
KiWinUS's Avatar
Great catch. For the trained professionals only.
KiWinUS is online now   Reply With Quote
Old 07-03-2025, 08:49 PM   #11
beast4765
I have had a problem in the past where the fuel line was too small. Also the electric fuel pump did not have enough volume to keep up
beast4765 is offline   Reply With Quote
Old 07-03-2025, 09:19 PM   #12
A bones
A bones's Avatar
Smile Re: Won't run past 3500 rpm
Gold right here
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 07-04-2025, 01:43 AM   #13
Flathead Fever
Flathead Fever's Avatar
I agree with A bones, try running it without the air filters and see what it does. I have a 324 olds engine in the '28 Mitchel Muffler Pickup. About 25-years ago when I rebuilt the engine. I adjusted the idle air fuel with the air cleaners off. When I sat the air cleaners on the carbs the idle dropped. I thought that was strange at just idle. They were two of those small flathead 97 style air filters I had laving here. I swapped them out to a different design and then then the engine could breathe. Pretty bad when air cleaners won't even flow enough air at idle. That might not be your problem, but it will be easy to check. Also, make sure the throttle valves are opening up all the way. I have not done it yet but I'm going to start installing air fuel ratio gauges on my cars when I build them, that's if I recover from the stroke I had. I used the ones on the smog machine at work to check the engine readings on the dyno, but I was never allowed to bring my personal vehicles into the phone company's garage, too many eyeballs watching us in the garage. It would be really cool to monitor the fuel ratio driving down the road to get everything dialed in. There's lots of videos on those gauges.
Old 07-04-2025, 05:05 AM   #14
tubman
tubman's Avatar
How does that engine breathe? I see it has an early intake manifold with no provision for a road draft tube. It does have the early style fuel pump stand where the air can get into the engine, but how does it get out? Unless provisions have been made for the air to get out some way (such as a PCV valve), it can cause problems. The air flow through the later (8BA,8CM) engines is opposite that of the earlier engines, so swapping intakes late for early is not a simple bolt on exercise.
BTW, I would consider changing out that intake manifold in any event. It's a textbook example of poor fuel distribution, especially if run with a straight linkage.
Old 07-04-2025, 07:26 AM   #15
chap52
chap52's Avatar
Great responses here. Interesting read for sure. Thanks... Chap
Old 07-04-2025, 07:43 AM   #16
Tim Ayers
I've seen them, but never held one on my hand. How do they work? Is it like a metering rod-type set up?
Old 07-04-2025, 08:39 AM   #17
34fordy
34fordy's Avatar
Yes.
My old 1942 Allis Chalmers WC with a Marvel Schebler carburetor had an adjustable main jet. A simple carburetor that worked very well.
34fordy is online now   Reply With Quote
Old 07-04-2025, 11:25 AM   #18
slowforty
What type of ignition resistor do you have. I had a bad one that would fail when it warmed up. Would not let the car run over 60 mph.
slowforty is offline   Reply With Quote
Old 07-05-2025, 06:09 AM   #19
Ken/Alabama
Ken/Alabama's Avatar
I’m thinking distributor issues.
Old 07-05-2025, 09:15 AM   #20
hueyhoolihan
i have similar symptoms with my '41 flathead.
and just a year ago had problems, again similar symptomes, with yet another of my vintage cars. and only two years ago with my 2012 four cylinder honds ST1300 motorcyle.
except for my current problem with the '41 (which has yet to be fixed), in all cases the problem was with an ignition wire that was working perfectly until the engine warmed up to a certain temperature and then all hell would break loose!.
on the honda it was an abraded sparkplug wire that was arcing and on the other vintage (1953) car it was the COIL wire that was arcing (it affected all four sparkplugs simultaneously, of course).
with the '41, i've replaced the fuel pump and can see that the sediment bowl is full at all times, and because the carb is brand new (although i've had it apart looking for a problems) i've been concentrating on the ignition, which has been disassembled numerous times too. it has had the points replaced and a new condenser installed. so am thinking coil...
so, currently have a new coil on the way. and if that doesn't fix it, i'll be installing new caps, both inner and outer, and if THAT doesn't fix it i'll be installing all new wires.
i don't like chasing problems by adding parts, but to be as reliable as i want to car to be, they probably needed replacing anyway. not to mention that i'll gain knowledge WRT the engine.
i'll be following this thread closely.
hueyhoolihan is offline   Reply With Quote
