Old 06-13-2025, 10:18 AM   #11
KULTULZ
KULTULZ's Avatar
Arrow Re: Tri-power issues
I have no idea of how you are driving the car on the street now with available pump gas.
As mentioned, ethanol laced fuel and heat soak are your main concerns. That big a$$ ACL ASSY also acts like an umbrella and won't allow engine heat to escape easily, especially after shutdown (heat soak).
11.4 to 1 CR and a very aggressive timing curve (all mechanical with no vacuum for the street).
READ HERE - https://enginefacts.com/ford406/
READ HERE - https://petroleumservicecompany.com/...ane-race-fuel/
I have seen these 5 GAL cans in gas stations close to race tracks.
If you want a true street driver, maybe consider building a mild 390/428 for the street and use the 3X2 with carb or TBI if you want the wow factor. Store the 406.
Who makes the other 3X2 TBI setup?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
