Old 06-06-2025, 11:04 AM   #1
David in San Antonio
David in San Antonio's Avatar
Default What top speed translates to maximum revs?
I’m running a rebuilt original block (not Burtz) with insert bearings, counterbalanced crank, Burtz head and cam, updated lifters.
Question: What is the maximum RPM (red line if it had a tachometer), and what speed in 3rd gear does this translate to?
I don’t want to over-rev it.
Thanks everyone.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 06-06-2025, 11:14 AM   #2
alexiskai
alexiskai's Avatar
Default Re: What top speed translates to maximum revs?
It’s not really a problem in third gear. The torque curve drops off sharply above 2500, so you can mash WOT and it won’t go any faster than about 60. After that it can’t overcome drag unless you’re going down a hill. Also your self-preservation instinct will kick in.
Old 06-06-2025, 11:19 AM   #3
nkaminar
nkaminar's Avatar
2,500 rpm is a reasonable red line, as Alexiskai said.
With a rear end ratio of 3.74:1 and 30 inch OD tires, 2,500 will be 59.7 mph. Any differences will ratio. For instance with a rear end of 4.11:1 the speed would be 3.74/4.11 X 59.7 = 54.3 mph. Or in another example, if you have an overdrive with an overall ratio of 3.00, then the car speed would be 3.74/3.00 X 59.7 = 74.4 mph.
It is quite easy to set up a spread sheet to calculate the mph. The only thing you need to know is that a mile is 5,280 feet and some simple math.
Old 06-06-2025, 11:32 AM   #4
Hitman
More importantly, are you running an overdrive or different rear end ratio? That will have an impact on the speed part of the equation.
Hitman is offline   Reply With Quote
Old 06-06-2025, 11:47 AM   #5
Chuck Dempsey
Chuck Dempsey's Avatar
Perfect....
Chuck Dempsey is offline   Reply With Quote
Old 06-06-2025, 11:57 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
I figured whatever the stock Zenith would allow— 2 days after I put it together aft I poured my own mains it rocked on compression at shutdown .
The next day I found it would do 67in a trip to Wisconsin on the way back it was at 65 the whole length of the PA turnpike and I am still trying to break it
I know the balance is off some ,the numbers on the speedometer end at 75 — that is my goal— stock compression,stock rear ratio but now I am working on the shocks and front end.
I bought the Stal 550 19 radials and had to change the speedometer gear to the one for 3:54 ratio to get the speedometer correct again.
I have driven the car over 60 a lot.
It is comfortable to drive 60-65 and on the long trip I averaged 23 mpg at that speed.
Kurt in NJ is online now   Reply With Quote
Old 06-06-2025, 12:00 PM   #7
HDowse
HDowse's Avatar
I’ve used this calculator for many years. It’s helpful if you are thinking of a differential ratio or overdrive change. Also it helps if you start thinking about changing tire size.
https://www.advanced-ev.com/Calculators/TireSize/
HDowse is offline   Reply With Quote
Old 06-06-2025, 12:49 PM   #8
Tom Endy
Tom Endy's Avatar
The attached may help.
Tom Endy
https://www.santaanitaas.org/wp-cont...Tachometer.pdf
Old 06-06-2025, 01:22 PM   #9
ModelA29
ModelA29's Avatar
I've got one of these cheapo $12 tachs from FleaBay. I like it has an hour meter.
https://www.ebay.com/itm/29733789364...Bk9SR7biwOfoZQ
ModelA29 is offline   Reply With Quote
Old 06-06-2025, 01:41 PM   #10
nkaminar
nkaminar's Avatar
With a 3.74 rear end, 30 inch diameter tires, at 5,000 rpm the car would be going close to 120 mph. At 10,000 rpm the car would be going close to 240 mph.
Old 06-06-2025, 05:10 PM   #11
frank55a
As several have said it depends on the gear ratio, if you have an overdrive and what the tire size is. What I was told back in the 60s by several different old timers is "Kid, you can't hurt it if you follow one simple rule,
when your ears start to itch its time to shift gears or slow down."
frank55a is offline   Reply With Quote
Old 06-07-2025, 10:06 AM   #12
I raised the question of maximum revs because above about 50 mph the engine becomes much louder and cacophonous. It doesn’t sound happy. But the consensus here seems to be it can sustain whatever high gear top speed it can muster. It has the original 19” wheels with Lucas tires, the original transmission and rear end, and no overdrive. It’s touched 70 mph on a wide, very smooth road. On typical Texas secondary roads I lose confidence much sooner. I never drive on interstates.
Alamo A’s Club
Old 06-07-2025, 05:08 PM   #13
old31
Well, that sounds perfectly ok with me!
old31 is offline   Reply With Quote
Old 06-08-2025, 03:16 AM   #14
TomInCologne
TomInCologne's Avatar
i assume he is using an hc head?
scnr
TomInCologne is offline   Reply With Quote
Old 06-08-2025, 08:05 AM   #15
32Ford13
I love and agree with: “Also your self-preservation instinct will kick in.”
Hahahaha.
32Ford13 is offline   Reply With Quote
Old 06-08-2025, 08:22 AM   #16
Six volt
“Your self preservation instinct will kick in”, still laughing at that one. It’s a coool line to remember and use sometime. Made my day.
Six volt is offline   Reply With Quote
Old 06-08-2025, 09:16 AM   #17
Fullraceflathead
Fullraceflathead's Avatar
Your self preservation instinct will kick in has gotten me this far in life so who am I to argue with it!!!!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 06-08-2025, 02:37 PM   #18
nkaminar
nkaminar's Avatar
My self preservation instinct did not kick in until I was 60. I'm a slow learner I guess.
Old 06-08-2025, 03:16 PM   #19
Kurt in NJ
Kurt in NJ's Avatar
Given that it is a modified engine with unspecified inserts and unknown oiling the limits for a original stock engine may not apply—
Old 06-08-2025, 04:44 PM   #20
stevemclark
stevemclark's Avatar
With 2 Morton-Thiokol solid fuel boosters you should reach escape velocity in 3 minutes.Take out the motor and drive line to lighten it . Self preservation does not apply with this application.
It's not the destination ,it's the journey .
stevemclark is offline   Reply With Quote
