Old 06-03-2025, 12:34 PM   #1
KCW
Default 26 T starter button bad?
I’ve been wrestling with starter issues for weeks. First my Bendix broke. Got that fixed and leaned a lot about repairing starters! Now my starter button is in the frizz. It smoked a little a few times when I pushed it, then after that it would only work intermittently, and now not at all. Is this something that happens often? I ordered a new button from Lang’s for 38$ or so. It seems like the old one is rivitted into place so I’m not sure how I’ll swap it out. Any ideas? All of this is new for me but I feel like I am making progress and learning a lot!!!
KCW is offline   Reply With Quote
Old 06-03-2025, 07:02 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 26 T starter button bad?
Is the old one rivited in place? I doubt Ford did that.
Old 06-04-2025, 12:03 PM   #3
rotorwrench
rotorwrench's Avatar
Use screws if it has to be drilled to remove it. Rivets don't make much sense for maintenance.
Old 06-04-2025, 12:20 PM   #4
stevests
stevests's Avatar
Can you post photos ?
stevests is offline   Reply With Quote
Old 06-06-2025, 04:40 PM   #5
jimvette59
jimvette59's Avatar
I have taken Model A starter buttons apart that are attached to the starter and turned the copper over and cleaned the surfaces it worked fine. JMO
jimvette59 is offline   Reply With Quote
Old 06-09-2025, 02:11 PM   #6
KCW
The button from Lang’s arrived. It looks similar but different from the one that I’ve got. I have a 26 T roadster pickup. Lang’s said their button works up through 1927. Did I get the wrong button? Photos attached of the new and old.
Old 06-09-2025, 03:05 PM   #7
J Franklin
J Franklin's Avatar
I think it will fit.
Old 06-09-2025, 05:30 PM   #8
stevests
stevests's Avatar
That's the good, tractor type switch - it will fit just fine. The "other" cheap imports are not good !
Old 06-10-2025, 12:02 PM   #9
rotorwrench
I don't know if the new switch would fit the old support bracket or not. If it will then you can drill or grind the rivets heads and remove them. Use the new screws to install on the bracket. Otherwise, just use the whole thing.
Old 06-10-2025, 03:24 PM   #10
KCW
Got the new one installed. The bolts were glued together so I had to remove them with a hack saw. Took forever! Got the new one hooked up. It’s not a perfect fit but it will do. The car started immediately! I think that button was partially fried for a long time because I can’t believe the power of the starter with the new button. Thank you everyone for the advice!
Old 06-10-2025, 03:24 PM   #11
KCW
By the way, the kit came with a button extension. It’s several inches long. Why would anyone need an extension that long?
Old 06-10-2025, 04:42 PM   #12
stevests
stevests's Avatar
Different body types had different height floorboards .
