Old 05-31-2025, 04:38 PM   #1
RGC1
Default 34 trans help
Hi. I have been rebuilding my 34 trans for my fordor so it’s been start and stop over a couple a months over getting time and getting parts. Thought I was finishing it off today.
All seemed good, before I had the front bearing retainer tight just snug, put the shifter in tested the gear shifting , seem to work good, pulled shifter back out, tightened up front bearing retainer, then noticed it’s snug to turn by your hand now to snug grab a rag and twist pretty good by hand.
Slack it off a bit, not much, turns over nice feels like it should.
Bought all my parts pretty much from Mac at Vanpelt sales and a few nos pces. So pretty confident everything is correct there. So I must have done something or missed something.
Before I start to dismantle thought I would throw it out there and see what the most likely cause would be ? Something I missed or did on the main shaft assembly I am assuming .
Thanks in advance.
RGC1 is offline   Reply With Quote
Old 05-31-2025, 05:13 PM   #2
RGC1
Default Re: 34 trans help
I don’t know maybe there is nothing wrong it’s just snug thought it would be a little looser to turn , maybe it’s the difference in gasket thickness I’m just not sure , just a little tighter than I am use to say with Muncie type four gear.
Old 05-31-2025, 05:31 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Is the u joint tightened up?
that pulls the main shaft tight to the rear bearing.
Old 05-31-2025, 05:47 PM   #4
RGC1
I don’t have the u joint portion on at this time only the retainer
Old 05-31-2025, 05:54 PM   #5
KiWinUS
KiWinUS's Avatar
Should spin freely
KiWinUS is online now   Reply With Quote
Old 05-31-2025, 05:56 PM   #6
RGC1
I just put it on feels about the same., Maybe it’s just me maybe there is nothing wrong , it’s not dumb tight it’s just a bit of a grip twist type turn just tighter than I would have thought . More like when you try and turn an automatic input shaft. …
I will try my pinion torque wrench and see what it reads
Old 05-31-2025, 06:01 PM   #7
RGC1
If I put my pinion torque wrench on the nut through the u joint it takes 25 inch pounds to turn it . About the preload of a diff. Is that slightly tight ?
Old 05-31-2025, 07:48 PM   #8
Will Kimble
Can you wiggle the synchro back & forth a little? Sometimes the brass cone will grip the main drive gear enough to drag
Will Kimble is offline   Reply With Quote
Old 05-31-2025, 08:43 PM   #9
RGC1
I have currently have it all buttoned up so can’t wiggle it right now
Old 05-31-2025, 08:44 PM   #10
Tim Brown
Tim Brown's Avatar
Is it dry in there or have you added some lubricants?
Tim Brown is offline   Reply With Quote
Old 05-31-2025, 11:13 PM   #11
cas3
All good advice above, pull the top cover, make sure the brass rings are not stuck, and oil things up
Old 06-01-2025, 12:05 AM   #12
RGC1
Yes everything is all oiled up and I did shift through the gears I will put the shifter back in it tomorrow and do it again and see how it acts, but yes used assemby grease in areas and poured some oil I rotating the gears before putting the top on.
Thanks everybody appreciate it
Old 06-01-2025, 06:03 AM   #13
Terry,OH
Terry,OH's Avatar
25"/# is too much. Is the transmission in neutral or in a gear? How does it turn in neutral?
Old 06-01-2025, 07:45 AM   #14
RGC1
Yes that is neutral
I would have to agree it just seems a little to tight
I just loosen off bearing retainer on either end a bit and it makes a noticeable difference and turns more like I think it should.
Old 06-01-2025, 07:59 AM   #15
Will Kimble
Just to be sure - stock ‘34 transmission? Do you have the oil baffle on the main drive gear? The early synchro is not held by a snap ring and should slide back and forth easily about 1/8”. If it hangs up on the main shaft that can be a problem. We don’t put assembly grease on the brass surfaces as it makes them grab sometimes, but we do spray with a thin lubricant called “power lube”.
Old 06-01-2025, 09:11 AM   #16
RGC1
Hi yes stock 34 transmission, Yes I remember correctly yes on the oil baffle
On the grease, I use a lighter one made by driven that I use for engine bearings during assembly.
I put a new synchro in it and seems to me it was hanging up at first until it was moving freely. Would It be worth trying the shifter , turning trans by hand and going through the gears see if it frees it up ?
Thinking to try a few things like that before I tear things apart which I am hoping not to have to do. It does turn smooth just tight
Thx
Old 06-01-2025, 09:22 AM   #17
Will Kimble
I would remove the shift tower and make sure the synchro is moving freely - not hung up on the main drive gear or second gear cone. Put the slider in neutral and then see how it feels. Do you have gaskets at the front & rear retainers?
Old 06-01-2025, 09:28 AM   #18
RGC1
Ok I will do that thanks. Yes I have thin gaskets at each end , and it seems like if I doubled one gasket up it would about the right amount of clearance seems like it’s about that close to be correct in my mind.
Old 06-01-2025, 10:18 AM   #19
Will Kimble
Pics would be helpful. Are you using the early front retainer (original) or the later one with the seal (78)?
Old 06-01-2025, 10:32 AM   #20
RGC1
I am using the original earlier one with out the seal I will see if I can figure out some pictures thx
