I have a question concerning the rear spring on a Model A, vs the rear springs on a normal/newer rear leaf spring car. On the regular leaf spring car, if you take the weight off the rear axle, you can disconnect the rear springs from the body/shackles, and remove the axle and springs without issue. Why is it so dangerous to do that with the Model A. If you take the weight off the rear axle, why can't you disconnect the spring from the body, and remove the axle with the spring attached. I have read articles on the subject, but still confused. Thanks..TommyJ..
The spring exerts force and and travel in 2 directions, Ends,- eyes come together and down for lift. The together at the eyes is not visible when the axle housings are in place. The ends are static. You need the spreader.
#3 | |
When in the car, not only is this spring contained within the channeled crossmember, the spring leaves are constrained by the two U-bolts that hold the spring assembly within the cross member. So - it's not that you cannot remove the axle assembly with spring attached, rather it's a safety issue that you should not lest that single bolt fail. Body parts are slim protection against that much energy released at once. Use the spring spreader, spread the eyes to release tension on the shackles, remove the shackles and then drop the axle assembly with the spring extended on the spreader. If you need to work on the spring then release the tension using the spreader, and only then remove the spring from the frame. We really don't want to read about you here as a "what not to do"...
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
to do the job safely, calls for a Model A spring expander. even then... it is a task best accomplished with a full understanding of what you are doing, what can go wrong, the consequences of such... and a lot of well thought out attention to detail!!
uh-huh ~
"My Model A... work never ends, only the day ends!" |
#5 | ||
Copy..so the pressure isn't off the spring with the weight off the axle. That make sense. Thanks. |
Tom Endy |
#7 | |
#8 | |
The front & rear springs are stretched when installed. So regardless of the weight acting on those springs, you should use a spring spreader to safely remove them.
Bob Bidonde |
The A also only has one spring streched out to support the cars weight where as a newer car has two springs with only one end in a shackle so there not streched or compressed to install (only after the cars weight is put on them)
A good time to restore the spring. That old center bolt is an unknown.
#12 | |
#13 |
Thanks for all the info. I don't plan on rebuilding the spring at this time, but you know how that goes! TommyJ
#14 |
The reason why the Model A springs are under tension is, as Phil Brown said, the springs on a modern car are attached to the frame at one end. That anchors the spring and keeps the axle in place. The springs on a Model A are not anchored but have shackles at both ends. So the tension keeps the axle more or less in the center of the car. A track bar will anchor the rear end to eliminate any side movement, however slight, in the rear end.
#15 |
Please advise: Rear spring bolt fractured!
My 30 coupe is getting an overdrive. I am in the planning stage. The rear spring bolt is missing the bottom half. I can feel the fractured upper half in the hole and feel the nut end on top of the channeled cross member What should I do in dropping the rear axle. As I let the axle down all but the last leaf should loosen and fall out and since nothing is retaining the spring it should be ok, correct? Diastole in the Smokies
A little learning is a dangerous thing. Drink deep, or taste not the Pierian Spring; There shallow draughts intoxicate the brain, and drinking largely sobers us again. |
#16 |
Here is a picture
#17 |
Two things:
I had to rebuild my Mitchell due to my mistake. I took the whole thing out at once but could not get it back in. I had to take the rear spring off, install it separately and then axle. But while it was out of the car I had at least one 6" clamp on it. going back in I had two more added and a chain-probably should have done that in the beginning. Either way I had to put it in separately and then the axle. Still hate dealing with that thing. Diastole: with a broken bolt that means there is nothing holding that spring pack together. So I think you have one option: Release the tension very slowly by raising the body off of the axle or dropping the axle. Making sure that the spring can't fly off in any direction. Do this by clamping the spring pack together, lower, add a clamp/chain, lower and add a clamp etc., etc. I am sure someone smarter than me will chime in with a better idea. My 2 cents worth. Mike
#18 | |
#19 | |
BTW, if you’ve never used a spring spreader, you will be surprised at how much oomph it takes to expand it to push the spring. That’s how much energy you are containing from escaping. The nut should be on the bottom of the spring, and it gets the threads of the bolt peened over after trimming to length. The square bolt head fits into the square hole in the crossmember to center the spring.
#20 |
You need the spreader. Check to see if your local club has one they loan.
Charlie Stephens |
