#41 | |
#42 |
The letters indicate the manufacturer of the body. In this case LeBaron, one of the companies that made bodies for Ford in the '30s (LeBaron, Murray, Budd, and Briggs if I recall correctly.
Ken
https://www.nirgv8.org |
#43 |
Ken,
My recollection is the same as yours. In this case, previously independent LeBaron was a subsidiary of Murray. The Great Depression eventually spelled the end for the independent body builders for the classic car manufacturers. |
#44 |
I don't understand why a body made by Murray (not LaBaron, a subsidiary of Murray) would have an "LB" name plate? Victoria bodies were made by Murray, not LaBaron. Why then should an LB plate be used for a Victoria?
#45 | |
Not all 34 bodies have the crows foot stiffening rib in the rear wheel tub. My 34 5 window coupe I am working on has flat wheel tubs and it didn't have any metal work done to the body until I started fixing it. It was still in the original black paint and not a lot of rust.
My guess would be that this was similar to a 27-28 type of deal where early cars could have some holdover from the previous year. I would bet that my car was a very early 1934. If I didn't have pictures to prove this, nobody would believe that the sheetmetal wasn't replaced. Quote:
#46 |
#47 |
#48 |
Yep; I checked all my 33/34 grills and radiators for the 'third bolt' and only found it on truck radiators and grills. Newc
#49 |
There are like 60 differences between the 2 years. I have been compiling a list of what I found:
grill emblems, Grills, radiator caps, Cowl vents, hood side vents, hood handles and how they hold down, hood tops, interior door handles and pulls, gauge placements, engine hp, door windows, inner fenders, door hinges, bumper brackets, color of interior knobs, luggage rack (33) only, paint color schemes 33 blk fenders, 34 it was an option, pin stripping, sun visors, cowl lacing bead on body |
