Old 04-30-2025, 07:16 PM   #341
TomC750
TomC750's Avatar
Default Re: What did you do today that was flathead V8 related?
Put a mechanical oil pressure gauge on my '41 Merc. She's one year younger than me. A little difficult, but gott'er done. And yes, not as easy as it once was.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 05-02-2025, 01:18 PM   #342
slowforty
Day 11
Took a test ride around the block. No problems. New transmission is a Lot quieter and shifts better, Some STP in the trans seems to have helped.
Thank you for your Support.
Roger
slowforty is offline   Reply With Quote
Old 05-02-2025, 04:43 PM   #343
ssffnomad
ssffnomad's Avatar
Nice Job Sir.
Enjoy
ssffnomad is offline   Reply With Quote
Old 05-03-2025, 02:56 AM   #344
Mart
Mart's Avatar
Well done Roger. It took a while but I bet you have benefitted from the activity and the car sound like it is happier.
Old 05-03-2025, 07:11 AM   #345
Model51
Model51's Avatar
Poured resin copies of the super rare 1935-1937 front tow hooks for big trucks. I borrowed an original set (first I've ever see in person) and then made a silicone mold using them as the pattern.
Just need a bit of flashing clean-up and I'll have a display set. Now I'm thinking of getting a set cast in ductile iron and maybe re-creating the special equipment front license plate holder too.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 05-03-2025, 02:00 PM   #346
Zeke3
Zeke3's Avatar
Dave, great looking parts!
I have been removing the spring shackles on the rear of my 1937 with the KRW removal tool, what a workout.
Zeke3 is offline   Reply With Quote
Old 05-03-2025, 04:43 PM   #347
fordv8j
fordv8j's Avatar
This week changed master cyl. and drivers side rear wheel cyl on our 1938 Ford conv.---had the correct puller, tightened real tight, pounded on it, nothing happened; put heat on it, pounded more, still failed; pot a lot more heat on it, got a 8# hammer, finally came off,job completed, not my favorite pass time
fordv8j is offline   Reply With Quote
Old 05-07-2025, 02:07 PM   #348
ndnchf
ndnchf's Avatar
All packed and loaded, ready to head to the Luray pre-war swap meet tomorrow morning. I'm bringung a variety of restored 1932 - 1954 flathead V8 generators, both 6 and 12 volt. If you are there, stop by and say hi!
ndnchf is offline   Reply With Quote
Old 05-07-2025, 04:43 PM   #349
petehoovie
petehoovie's Avatar
Old 05-07-2025, 10:37 PM   #350
Kelly Burns
Kelly Burns's Avatar
Went for a drive!
File Type: jpg My 47 at OWB with Flyby Original 052501.jpg (60.2 KB, 233 views)
Kelly Burns
Kelly Burns is offline   Reply With Quote
Old 05-07-2025, 10:58 PM   #351
petehoovie
petehoovie's Avatar
Originally Posted by Kelly Burns View Post
Went for a drive!
Old 05-08-2025, 07:25 AM   #352
Kelly Burns
How did you do that? Lol.
Kelly Burns
Old 05-11-2025, 10:34 AM   #353
slowforty
Wander out to the garage. Cleaned up the aftermath of the transmission replacement. Put all the stuff needed for a trip around the block. Same stuff is need for any trip. Regardles of the length, One mile or a 100.
Old 05-11-2025, 10:43 AM   #354
Kens 36
Kens 36's Avatar
...or 179 to Springfield. Are you bringing it?
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 05-11-2025, 11:45 AM   #355
Mart
Mart's Avatar
I've been working on my 32 sedan body and paint for the last 6 months. Today I took it out on the road for the first time this year. It started up great! Having a priming fuel pump helps a lot. I also had to start and move my 57 Thunderbird to get the sedan out. That started well as well, so all in all a good result as I achieved what I set out to do.
Old 05-11-2025, 07:01 PM   #356
fordv8j
fordv8j's Avatar
Yesterday drove the 38 conv. coupe about 135 miles on tour with a local club
Old 05-12-2025, 01:26 AM   #357
Lawrie
Lawrie's Avatar
Set up the new 3.54 ring and pinion in the 34.
One thing is that to get the contact patch nice it needs a .060 shim under the pinion bearing. other wise the contact is way too high, right on the top of the tooth.
so ,after. a days work, I have a nice contact patch and .008 b/lash.
tomorrow I will finish the assy of the rear axle and refit it,
BUT , I. thought I may try with a thinner shim under the pinion ,just to see.
I have all the shim and gaskets written down so I have a datum to return too.
Lawrie
Old 05-12-2025, 07:05 AM   #358
sidevalve8ba
sidevalve8ba's Avatar
I finally got around to adjusting my drag link so that my '32 pickup. steers the same amount in both directions now. Sure makes for easier maneuvering in tight spaces. So I took it for a test spin and stopped by a parts house for some items. Then filled up with non-ethanol. I sure enjoy the torque of that 276!
sidevalve8ba is online now   Reply With Quote
Old 05-12-2025, 10:11 AM   #359
ndnchf
ndnchf's Avatar
Originally Posted by sidevalve8ba View Post
I finally got around to adjusting my drag link so that my '32 pickup steers the same amount in both directions. Sure makes for easier maneuvering in tight spaces. So I took it for a test spin and stopped by a parts house for some items then filled up with non-ethanol. I sure enjoy the torque of that 276!
Do you happen to need a restored 1932 generator? I'm sure you know how rare they are - one year only. Post mount. I have many restored generators available, but only one 1932. $425 plus $29 shipping and insurance to a US address.
Old 05-12-2025, 10:58 AM   #360
petehoovie
petehoovie's Avatar
The Versa-Vise is a very handy tool...
