Old 04-28-2025, 01:00 PM   #1
Fredb_
Fredb_'s Avatar
Default SN location on 1926 Ford PU
I’m looking at a 26 Ford today and wanted to compare an on frame to engine. Can someone tell me where to find these two numbers on the 26 T pickup? Thanks
Fredb_ is offline   Reply With Quote
Old 04-28-2025, 04:12 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: SN location on 1926 Ford PU
Try looking under the floor boards on the passenger side along the frame rail— it wasn’t until sometime in 1925 that they sometimes started putting the numbers on the frame
Old 04-28-2025, 07:47 PM   #3
stevests
stevests's Avatar
The Ford serial number for the engine is on the driver's side block above the water inlet connection - bonus for you IF the numbers match !
stevests is offline   Reply With Quote
