Old 04-08-2025, 10:51 AM   #1
Proartguy
Default No Diesel oil
I read a couple of posts about using diesel oil because it has more anti-wear additives. I changed oil and used diesel and 50 miles later it had a knock which turned out to be a rod bearing.
Yes, diesel oil has more wear additives, but it also has more detergent for the soot byproducts. Subsequently I saw a couple of articles about this since my mistake.
https://bangshift.com/bangshift1320/...n-your-engine/
Proartguy is offline   Reply With Quote
Old 04-08-2025, 11:27 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: No Diesel oil
I have used Shell Rotella 15-40 for many years with zero issues. Any of my engines I have taken apart with many miles on still look new. What condition and miles were on your engine prior to changing oil? I believe there may be more to this story.
KiWinUS is online now   Reply With Quote
Old 04-08-2025, 11:47 AM   #3
tubman
tubman's Avatar
I've always wondered why some people insist on using a product recommended for uses it was not designed for.
Perhaps the panache of diesels, you know, those broad-shouldered semi-trucks pulling incredible loads through the Rockies, driven by brawny, ruggedly handsome teamsters?
Old 04-08-2025, 01:04 PM   #4
cas3
cheapest diesel oil I can find in my fleet for several decades now. No issues.
Old 04-08-2025, 02:12 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
> > broad-shouldered semi-trucks pulling incredible loads through the Rockies, driven by brawny, ruggedly handsome teamsters?> >
Yep. Like Ms Willem & her 389. Brawny, Rugged, A PeterBilt driver for sure.
Jack E/NJ is online now   Reply With Quote
Old 04-08-2025, 02:15 PM   #6
petehoovie
petehoovie's Avatar
I like the split windshields on Peterbilts...
Old 04-08-2025, 02:16 PM   #7
Proartguy
Not certain how many miles are on the engine. I was told it was rebuilt before I bought it and certainly appeared pretty fresh when we took it apart.
I included a link to an informative video about the reasons why it is not a good idea to use diesel in gasoline engines so it would not be just my opinion. I realized there would be those who could recount how good it works for them and refute this. Not my facts - watch the video.
Old 04-08-2025, 02:54 PM   #8
RalphG
RalphG's Avatar
The video was talking about fuel injected engines. I've run Case-IH 15w-40 diesel oil in my flathead Merc for the past ten years with no worries. For no other reason than I had that oil on hand at the time. I've since used 10w-30 diesel oil in several IH sixes and a GM V8. All carbureted old engines and working just fine. No worries about zinc just trying to have more engines running the same oil to simplify things.
RalphG is offline   Reply With Quote
Old 04-08-2025, 03:20 PM   #9
Jack E/NJ
Jack E/NJ's Avatar
> >I changed oil and used diesel and 50 miles later it had a knock which turned out to be a rod bearing.> >
After only 50 miles, much more likely a coincidence than oil change being the cause. If it was mine, I'd search for more likely causes.
Old 04-08-2025, 03:33 PM   #10
noboD
I doubt the oil caused your problem.
noboD is offline   Reply With Quote
Old 04-08-2025, 03:43 PM   #11
Gene1949
Gene1949's Avatar
Yup, UNLESS the op's motor was so sludged up it plugged the oil pickup
Gene1949 is online now   Reply With Quote
Old 04-08-2025, 03:44 PM   #12
jimTN
I too have been using diesel oil in all my cars and farm equipment, that includes T, A and V8's with no problems.
Old 04-08-2025, 04:05 PM   #13
Seth Swoboda
Seth Swoboda's Avatar
Shell Rotella 15-40 is good engine oil. It would not have caused an issue alone.
One thing you never want to ask a truck driver..... how's your Peterbilt?
Old 04-08-2025, 04:36 PM   #14
ford38v8
ford38v8's Avatar
I would say Miss Willem has a nicely split windshield also...
Alan
Old 04-08-2025, 08:00 PM   #15
Kube
Super Moderator
Kube's Avatar
I would say you are officially blind.
Old 04-08-2025, 08:27 PM   #16
tubman
tubman's Avatar
I would say it's not her windshield that is split.
Old 04-08-2025, 09:04 PM   #17
GB SISSON
GB SISSON's Avatar
I too use diesel oil. Chevron Delo, Shell Rotella or Napa house brand. Seems one of those is on sale at our Napa store here on any given week. I don't think a connecting rod knows if it's in a gas or diesel engine and at 21:1 CR and corresponding torque after firing, the film of oil on the rod bearing and wrist pin has to hold up to the task. I'm sure that diesel oil is more than capable of lubricating our V8s.
Old 04-08-2025, 09:11 PM   #18
tubman
tubman's Avatar
The reason that diesel oil isn't good for gasoline engines is because of the different additive packages. Essentially, the soot dispersants required in diesel oil react negatively with some of the additives required by gas engines and render them ineffective. Here's a video I found on a Corvette site that explains why in detail. If anyone can watch it and fully comprehend it, they will switch back from diesel oil tomorrow. https://www.youtube.com/watch?v=HcJHJL5Ys-Y&t=9s.
Old 04-08-2025, 10:07 PM   #19
trulyvintage
trulyvintage's Avatar
Exclamation Biodiesel Fuel
As mentioned before - diesel oil probably was
not the cause - however - for older diesel
engines biodiesel fuel should be
avoided - the higher the content the less
lubricants reach critical wear parts and
the increased cleaning action strips what
little film is left - causing metal on metal
friction and catastrophic failure.
Jim
trulyvintage is online now   Reply With Quote
Old 04-08-2025, 10:17 PM   #20
Lanny
Lanny's Avatar
If one of us guys would ask Ms. Willem how she likes her Peter Built,
I THINK HER ANSWER WOULD BE x RATED.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
