Old 03-29-2025, 01:57 PM   #1
Mart
Mart's Avatar
Default 32 Tudor door latch/ window channel problem (fouling).
Hello. On my 32 sedan The two channels that support the rear window channels in the front doors were broken. I repaired them and now I have fitted them I have a problem. The door latch fouls the channel when I try and open the doors. One fouls so bad I can't open the door. The part that fouls is the striker and the area that fouls is arrowed in the picture. It must be said the area is very congested and Ford seemed to have struggled with this judging how the channel is cut away to such a degree it is seriously weakened in this area.
Is this a known problem? Does anyone have any helpful tips to get around this?
Any help appreciated. Mart.
Old 03-29-2025, 02:04 PM   #2
Mart
Mart's Avatar
Default Re: 32 Tudor door latch/ window channel problem (fouling).
Hard to show but this shows the relationship when in situ. The striker hits the back of the channel.
Old 03-29-2025, 03:32 PM   #3
325w
What did you use for channel? What size is the channel
325w is offline   Reply With Quote
Old 03-29-2025, 05:19 PM   #4
Mart
Mart's Avatar
The channels: One is stock but repaired where it had broken in two (lower picture) The other is stock on the bottom with a new top fabricated. Both are pretty straight.
Old 03-29-2025, 09:23 PM   #5
Karl Wescott
Karl Wescott's Avatar
United Pacific reproduces them. Photo lifted from their website.
Karl Wescott is offline   Reply With Quote
Old 03-29-2025, 10:28 PM   #6
petehoovie
petehoovie's Avatar
Old 03-30-2025, 10:22 AM   #7
Mart
Mart's Avatar
I worked out what the problem was. I had repaired the strikers by building them up with weld. I had made them too long. The result was they had to be withdrawn further to release the door. The extra travel was causing the interference with the channels.
I cut down the strikers to a more reasonable length. That did the trick.
Mart.
