Old 03-12-2025, 11:37 PM   #1
GB SISSON
GB SISSON's Avatar
Default 9" rear in a jailbar truck
I have been reading a thread tonight that goes into quite a discussion about the problematic axles in a banjo rear end. I have read tales of sphincters tightening as nuts are twisted, wheels with drums flying into oncoming traffic, threads stripping, cracks appearing, keys shearing and then going through it all again if you'd like to check out your brakes...
Ever since I built and installed a 276 flathead mated to a T-5 in my truck based woodie wagon I have been thinking about completing this powertrain 'upgrade' with a 9" 4:11 rear from a '57-'72 Ford 1/2 ton pickup. IIRC this is a simple and direct 'bolt in' to my jailbar springs and driveshaft. I see there are quite a few guys on CL and Marketplace who sell these and seem familiar with inspecting and general overhaul. Since my woodie is far from being an original anything, why would I Not want to go this route? Right now, all seems fine, but I can now go 70 on the interstate and seems like a good move for piece of mind as I venture further from home in my 'semi-retirement' phase. Thanks, Gary
Old 03-13-2025, 12:12 AM   #2
Scotty's 52 F3
Scotty's 52 F3's Avatar
Default Re: 9" rear in a jailbar truck
Sounds like a good plan to me. Safer for you and yours and that truck you built is the only one like it on the planet. Axle failure at 70 MPH would be bad.
Scotty's 52 F3 is offline   Reply With Quote
Old 03-13-2025, 12:14 AM   #3
ford38v8
ford38v8's Avatar
Gary, I hear tell, (no experience myself) that a 9" is overkill for a flathead, an 8" being more appropriate. Perhaps a comparison of options here would benefit your goal? I believe they both have the common ratios of 3.27, 3.55, and 3.73, the 9" being used for F250/F350, the 8" for F150. more info than that is above my paygrade.
Alan
Old 03-13-2025, 12:42 AM   #4
petehoovie
petehoovie's Avatar
Old 03-13-2025, 04:45 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
I think it comes down to what do you have available and at what price? A 9" rear is definitely overkill from a strength perspective, but there are more parts available for 9" Ford rear ends than probably any other made.
However, a good 8" Ford rear is lighter, has all the ratios you could want and there were definitely some that were 5 x 5.5 bolt pattern. Either one will work - just find a good one at a fair price. . I think a gear ratio of 3.73 or 4.11 would work out fine with your overdrive setup. I would probably choose a 3.73 if I had a choice.
Old 03-13-2025, 07:04 AM   #6
tom1948
I'm using A 1999 8.8 from a merc mountaineer in my 1948 merc coupe. It has 3.73 gears, posi. and is 1/2" narrower than the original unit. I think a pre-1999 unit w/o disc brakes would work fine with your set up. they're pretty stout rears. just my useless opinion. lol, tom
tom1948 is online now   Reply With Quote
Old 03-13-2025, 07:45 AM   #7
GB SISSON
GB SISSON's Avatar
The F-250 and F 350 would be full floaters with 8 lugs. There were some F250s with semi-float but still 8 lug. These 3/4 amd 1 tons would typically have a dana 60, or in later years a sterling 10 1/4. The 4:11 is absolutely perfect for the island with so many hills and really 60 is more comfortable on the rare freeway trips. My rear tires are a bit over 30" tall so there's a little 'rubber overdrive' as well. Most of the 8 and 8.8 seem to be set up for the springs being under the axle, and mine are above. I have moved and welded spring pads before but the '57-'72 seem the best fit. I'm glad I have received a favorable response on this subject and thanks for the input. And I do kinda like a bit of 'overkill' sometimes. I will continue my research!
Old 03-13-2025, 07:54 AM   #8
pistonbroke
Hi Gary, Back in the day when I put a 9" out of a 64 thunder bird in my 42 jail bar. the width was good as in it looked right and the pinion yoke length worked as well. I did it for the 3.00 gears back then. The only issue was the lugbolt pattern but I just put on a set of custum wheels and all was well. Tim
Old 03-13-2025, 08:19 AM   #9
Karl Wescott
Karl Wescott's Avatar
I think something missing in this discussion is the weight on the axle. Engine torque and thrust are not the only considerations, the load carrying ability of the rear end structure and bearings should be considered as well as the braking torque on the axle housing (related to total weight of the vehicle). If Gary is not going to carry more weight than the 1/2 ton pickup at full capacity he should be just fine. If the rear end will be overloaded then think bigger. The 8" is a great little rear end (emphasis on LITTLE) and should be reserved (and preferred) for roadsters, coupes, and pre 1935 sedans.
Karl Wescott is offline   Reply With Quote
Old 03-13-2025, 09:19 AM   #10
TomT/Williamsburg
TomT/Williamsburg's Avatar
I think it is a great idea - with parts, brake shoes, and the complexity of changing anything in a banjo rear, it really is a no-brainer, 9 or 8”. There are more readily available junk yard pumpkin gearsets for the 9 vs 8” rears so 9” overkill - yes - practicality the 9” is a clear winner in my book. Oh - if you are running a 5.5” bolt pattern go 9”.
Go for it!
TomT/Williamsburg is offline   Reply With Quote
Old 03-13-2025, 09:52 AM   #11
37 truck
I went the 9" route with 3.73 ratio and a t-5 transmission behind a warmed-over flathead, and love the result.
37 truck is offline   Reply With Quote
Old 03-13-2025, 10:12 AM   #12
51504bat
51504bat's Avatar
A rear end from an earlier Bronco would be a good choice with 5 on 5 1/2 bolt pattern but they are more $$ than 1/2 ton units IIRC. Plus the springs are on top of the axle tubes, again IIRC. An 8 inch out of a Maverick would be a good choice based on it's 56.25 WMS to WMS but it's 5 on 4 1/2 and most are high 2's or low 3's ratios.
Old 03-13-2025, 10:20 AM   #13
cas3
I think its a good idea. The rear that was popular with those darn kids was the 57 -59 ford car 9" rearend as it was the best match in width for the old Ford bodies.
61 1/4". 57-72 f100
57.1/4" 57 -59 car
I can't remember, is your open drive banjo wider than 48 cars?
Old 03-13-2025, 03:30 PM   #14
Als48
Gary, This sounds like a good idea to me, from reading how much work is involved in working on brakes or axles, etc on a banjo-style rear. This may be a more HAMB related discussion, but there may be another option. Don't know if it would be much if any cheaper, but there is an outfit in California (Where else?) that can provide 9" axles, bearings, and such for your existing rear. It would probably involve a complete rebuild of the assembly anyway, tho. to get to where you would like to be.
Al Hook
Don't forget: "Murphy's law is one of the natural laws that you don't read about in the psysics books"
Als48 is offline   Reply With Quote
Old 03-13-2025, 05:00 PM   #15
GB SISSON
GB SISSON's Avatar
61 1/4". 57-72 f100
57.1/4" 57 -59 car
Skip, probably so. The pickups got a 2 1/2" increase in width in '42. This was also true of the tonners. My '38 tonner express had 46 1/2" between rear fender wells in bed. Imagine what I went throgh as a cabinetmaker running that thing all those years. The jailbar tonner express has 49" clear! The tailgate closes too.
Old 03-13-2025, 05:52 PM   #16
cadillac512
cadillac512's Avatar
I've never seen an 8" with 5.5 bolt pattern. 8.8 sure...but not 8". A 9" from a pickup would be perfect. That's a good plan, GB, and you'll be glad you did it.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 03-13-2025, 07:27 PM   #17
expavr
expavr's Avatar
Gary
I would definitely stick with the 4.11 ratio. When driving the local rural roads in 3 speed standard drive, I’ve found it useful on the Tonner in combination with the engine compression to assist braking. Also useful when pulling a trailer or a parade float.
Les
expavr is offline   Reply With Quote
Old 03-13-2025, 07:50 PM   #18
Bored&Stroked
I had one out in SoCal about 40 years ago (was going to use the axles in a banjo build) . . . I believe I still have the 28 spline axles in my Mom's garage.
Old 03-13-2025, 07:57 PM   #19
GB SISSON
GB SISSON's Avatar
Originally Posted by expavr View Post
Gary
Les
Last time I was in Hansville I didn't notice any superhighways! As far as the 4:11 goes, I have learned through 48 years on this giant rock that it's as tall as I want here. Keep in mind I'm partial to tall narrow tires, and HP just north of 100 at best. It's that Borg Warner OD that keeps me truckin' on Interste 5
Old 03-13-2025, 11:05 PM   #20
TomT/Williamsburg
A 9 or 8” is alot easier to work on, parts are still readily available, and it’s a much stronger than a banjo, 8 or 9”, for a 1/2 ton truck. For me, I think 75 mph at 2500 rpm - there are calculators out there to figure this out w/5th gear ratio, tire diameter, gearset - a flathead’ needs hesat and its sweetspot is 22-2800 rpm. My avatar w/stock flathead can run 85 mph at 2800 rpm and never missed a beat and never overheated. Stick in the 8 or 9” - you won’t regret it!
