Old 02-19-2025, 02:51 PM   #1
deuce_roadster
deuce_roadster's Avatar
Default 34 victoria passenger side door glass
I have everything to put the new glass into the door of a friend's car, however the bottom fell off the old glass before I could get it out and I am wondering which way the new metal channel goes on the glass. I have the measurments from the old glass as to position, but I can't find anywhere that shows which side the stud that sticks out, that allows the glass to move back opening up the "vent" area at the front. I am sure all 34s have this the same way, it either points toward the inside of the car or outside of the car, and I don't want to put the channel on wrong on the new glass. I had a 34 sedan delivery 30 or 40 years ago but just don't remember. I am sure someone here had done a 34 passenger car door. Thanks in advance.
Old 02-20-2025, 05:11 PM   #2
Proartguy
Default Re: 34 victoria passenger side door glass
The stud is towards the inside. To install the mechanism it has to be out of the track.
Proartguy is offline   Reply With Quote
Old 02-20-2025, 05:16 PM   #3
Proartguy
Here is what I wrote about this.
https://www.fordbarn.com/forum/showt...30#post2348430
Old 02-20-2025, 09:23 PM   #4
deuce_roadster
Proartguy, Thanks a million!! I didn't want to have the metal on the glass in the wrong way as breaking a new window removing it would certainly be bad luck. I will read your article.
