Old 02-14-2025, 09:06 PM   #1
TomC750
TomC750's Avatar
Default Water pumps
I have resumed work on my 8RT for my 8NV8 tractor. Both water pumps need replacing. Is there any advantage in getting them rebuilt? Years ago I broke a pulley on one attempting to rebuild it. I was successful with the other. I then found another leaker with a perfect casting, sent it in as a core to a well known early Ford parts supplier. The pump I received back was junk, hardly any tube, most of it rusted away. I saved it, but it took a good bit of work. Maybe I am better off springing for new ones at around $80 per?
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 02-15-2025, 07:44 AM   #2
38 coupe
38 coupe's Avatar
Default Re: Water pumps
If your tractor conversion uses regular car or truck type pumps then buy the new ones.
Old 02-15-2025, 09:19 AM   #3
pistonbroke
I went with new because as you found out you don't always get your originals back and what you do get back may not be as nice as what you had. Tim
Old 02-15-2025, 10:06 AM   #4
Tim Ayers
I've used Skip Haney before, but recently picked up a set of Bob Drakes improved water pumps. Either way, I think you can't go wrong.
Tim Ayers is online now   Reply With Quote
Old 02-15-2025, 12:00 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
I'd pickup a new set from Drake. The later pumps had the improved vanes and ball bearings vs bronze sleeve bearings - so they are much better than the stock earlier pumps. I'd not waste my time and $$$ rebuilding the later pumps.
Old 02-15-2025, 05:33 PM   #6
Texasroadkill
Texasroadkill's Avatar
Any pictures of the tractor? I'm looking to build one in the near future. What kit if any did you use?
Texasroadkill is offline   Reply With Quote
Old 02-15-2025, 08:14 PM   #7
TomC750
TomC750's Avatar
I do not remember the name of the kit supplier, I built it around 20 years ago, and that supplier is no longer in business. however, there is another outfit producing a kit. And I do not remember that outfit's name either! A lot of help I am! An internet search should turn it up though. I may have a pic or two of the tractor. I will look.
TomC750
1930 1 Ton White
Old 02-15-2025, 08:19 PM   #8
TomC750
TomC750's Avatar
Thanks for the replies, I have not checked with Drake yet, but I will. I have to order rings, bearings, valve seals etc. as well. I'd better get busy on a list. Spent today using a 7/16th tap chasing the head bolt threads.
TomC750
1930 1 Ton White
Old 02-15-2025, 08:30 PM   #9
tubman
tubman's Avatar
Arghhh. I wish you would have told us yesterday about your plans for today. Using a regular tap to chase flathead head bolt threads in the block is NOTrecommended. Those threads are cut to a different standard than normal so they will seal better (a bunch of the head bolt holes go right through to the water jacket). It's better to use a genuine Ford head bolt with 3 or 4 grooves filed in it as a chaser.
Not to worry, if you search the forum you will find sealers recommended that usually solve the leak problem resulting from this. If you still have leaks, there are several block sealing products that also work well.
Old 02-15-2025, 09:19 PM   #10
TomC750
TomC750's Avatar
Well, hard for me to believe I did any harm. The tap went in smooth and easy until it got past the reach of the bolt, then there was rust. I have forgotten my "class of threads", but I would expect the bolts to be in that class that allows for a close fit. We rebuilt a lot of flatheads back in the day, I never recall having a leak problem.
TomC750
1930 1 Ton White
Old 02-16-2025, 12:24 PM   #11
Shoebox
Shoebox's Avatar
I went to buy a pair,.....SOLD OUT
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 02-17-2025, 10:36 AM   #12
TomC750
TomC750's Avatar
Thanks, I will shop around.
TomC750
1930 1 Ton White
Old 02-17-2025, 10:44 AM   #13
Brendan
Brendan's Avatar
Send your Pumps to Skip Haney
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-17-2025, 10:46 AM   #14
Donaldoster
skips product is far better than any of the repopos
Donaldoster is offline   Reply With Quote
Old 02-17-2025, 10:54 AM   #15
TomC750
TomC750's Avatar
Tubman, threads are cut to a different standard than normal? What standard? They certainly are not AN or NS bolts as used in aircraft or they would be marked as such. I have been reviewing my Engineering Handbook and measuring major diameter, pitch diameter, etc. on the bolt threads as well as the block. This suggests that the threads in the block are class 2 or 3, and the easier to measure bolts are 3. In any case mine are well within spec. Interestingly, a new grade 8 nut is a looser fit on a headbolt than the headbolt in the block.
In another publication, "Best Shop Practices" it states "that when rebuilding assemblies it is important to use an appropriate tap to clean any debris out of the threads. Any other method may imbed particles in the threads and influence torque values." Case closed.
TomC750
1930 1 Ton White
Old 02-17-2025, 10:56 AM   #16
TomC750
TomC750's Avatar
Address or website for Skip?
TomC750
1930 1 Ton White
Old 02-17-2025, 11:35 AM   #17
Bob C
https://skipscoilsandpumps.com/
Old 02-17-2025, 11:41 AM   #18
TJ
TJ's Avatar
I've used Daryl Fryer for rebuilt pumps. He advertises in the V-8 Times and he does a great job.
Old 02-17-2025, 12:24 PM   #19
cadillac512
cadillac512's Avatar
Speedway Motors has the modern style pumps in several styles in stock. I've used two sets of those recently and they are excellent.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 02-17-2025, 02:30 PM   #20
TomC750
TomC750's Avatar
My kit was from Stauffer, no longer produced (I think) I did modify it some. The kit is currently produced by Awesome Henry. Any pics I have of my tractor are apparently on my other computer which is sick. I will come up with them eventually.
VanPelt has a neat video of a conversion on their website.
TomC750
1930 1 Ton White
