Old 02-02-2025, 04:38 PM   #1
rockfla
rockfla's Avatar
Default Any tried and true method of removal?
Any of you guys have a tried and true method of removing these vacuum set screw plus from intakes? I obviously tried a screw driver to NO avail and it finally skipped SO I stopped before I mess anything up any further!!!
Thanks!!!
Old 02-02-2025, 04:54 PM   #2
Model51
Model51's Avatar
Default Re: Any tried and true method of removal?
I had the same problem with cast iron valve covers. I ended up carefully drilling it out incrementally increasing drill bit diameter until I was afraid of hitting the threads or the bottom seat in the valve cover. Then I used a pick to pry the remaining brass bits out (along with some choice words which are inappropriate to mention here). Obviously I had the valve cover on the bench and not on the engine.
I think the issue of dissimilar metals is the culprit. Looks like you have a harder challenge with soft aluminum.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 02-02-2025, 06:51 PM   #3
rockfla
rockfla's Avatar
Thanks Dave
The current plan is to remove the intake so I can get a better angle on it and not contaminate anything else and do just as you have described…..I can’t think of any other way!!!
Old 02-02-2025, 07:42 PM   #4
tubman
tubman's Avatar
Originally Posted by rockfla View Post
Thanks Dave
If you can get a straight shot at it from the inside, it would be easier to drill it out and the drill might catch and run it right out. Or is this what you meant by a "better angle"?
Old 02-03-2025, 04:15 AM   #5
Mart
Mart's Avatar
Hand held impact driver? The type you hit with a hammer?
Old 02-03-2025, 05:28 AM   #6
69a
I'd start with a drill. Make sure you are as close to the centre as you can get. Put a deep center punch mark on it. Hit it with the center punch maybe 50 times, not too hard. Drill a hole about a 1/4 of the thread size. Try to get as much heat into it as you can with the drill. Try an easy out if you have one, or turn it over and drill it from the inside, with a drill about 1/2 of the diameter of the screw, using slow speed and a fair bit of pressure. If it hasn't come out already Just keep drill slightly bigger holes until you just break though the wall of the screw. Then get a fine punch and gently collapse the remainder into the hole.
69a is offline   Reply With Quote
Old 02-03-2025, 07:17 AM   #7
Terry,OH
Terry,OH's Avatar
Heat the area around the plug with a propane torch, DON'T have to get it very hot, lots of expansion to aluminum and pot metals.
Old 02-03-2025, 08:35 AM   #8
pistonbroke
A combination of Mart and Terry with a shot or two of PB blaster when hot normaly works. The aluminium will exspand much farther and faster then the steel plug. This should break the bond and also alow the oil to get down in the threads. Tim
Old 02-03-2025, 11:41 AM   #9
Brendan
Brendan's Avatar
dont the intake have a taper for the fitting? you could end up messing that up by drilling it out
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-03-2025, 03:08 PM   #10
35fordtn
35fordtn's Avatar
Just did one of these two weeks ago. Used my mini-ductor and a shot of free-all and it came right out
Old 02-03-2025, 03:09 PM   #11
Tim Ayers
If you fool around with old Fords regularly, I can't recommend a heat induction tool highly enough. They are a life saver.
Old 02-03-2025, 04:48 PM   #12
pistonbroke
Tim, I'm always looking for a better tool. What heat tool do you have? Tim
Old 02-03-2025, 05:17 PM   #13
Tim Ayers
Hey Tim,
I got the Bolt Buster brand tool. Mainly because it's made in the USA. Since I got it, the torches only come out for cutting. It's been a life saver for our daily drivers and old Fords.
https://boltbusterinc.com
Old 02-04-2025, 12:54 AM   #14
deuce lover
deuce lover's Avatar
Not tapered.
Old 02-04-2025, 12:26 PM   #15
Bored&Stroked
Bored&Stroked's Avatar
I have to ask . . . what the heck is a "mini-ductor"???
Old 02-04-2025, 12:29 PM   #16
rockfla
rockfla's Avatar
Whaa Laaa
