Old 02-02-2025, 06:39 AM   #1
benbuilder
Default General light question 1931 a
I just bought a 31 Model a pickup.
Supposedly ran when parked about 8 yeas ago. working on getting it going.
The headlights have two sockets in each shell. I have no bulbs in any of the 4 holes. I have never had a Model A so forgive me. I see diagrams, but cant figure out what the bulbs do. Help please
When searching for bulbs, am i correct to think that they are as follows?
the main headlight- is it a 6 Volt - #1188 bulb?
The other upper and offset bulb is a #1129A bulb, 6v, amber? Is this a park light?
benbuilder is offline   Reply With Quote
Old 02-02-2025, 08:40 AM   #2
Ayers1
Ayers1's Avatar
Default Re: General light question 1931 a
I'm not sure of the numbers but you're correct. The center socket is for the bigger high/low headlight bulb. The socket at the top is for the smaller parking light. They came originally with a clear bulb but a lot of people choose to install amber.
Ayers1 is offline   Reply With Quote
Old 02-02-2025, 09:46 AM   #3
Badpuppy
https://www.fordbarn.com/forum/showt...ighlight=bulbs
Harf to find 6V amber.
Old 02-02-2025, 09:52 AM   #4
old31
My only suggestion would be to get the 32/50 headlight bulb. This would give you 50 CP "candle power" on high beam. Order in few extras of all bulbs that you purchase, therfore saving on shipping costs.
https://www.snydersantiqueauto.com/p...6405&cat=41889
old31 is offline   Reply With Quote
Old 02-02-2025, 10:11 AM   #5
Badpuppy
50 CP probably not much brighter than 21 CP. Drains the battery faster. Generator can produce only so much power.
Old 02-02-2025, 10:13 AM   #6
Ayers1
Ayers1's Avatar
If you plan on driving much at night then you may want to check out Logolite. They have LED headlight bulbs. They are a little pricey at $100/pr but in my opinion, definitely worth it.
Old 02-02-2025, 11:16 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
I agree. The LogoLites LEDs are much brighter than incandescent bulbs. I have mine on during the day to ensure others see me. Very little draw on the battery.
Old 02-02-2025, 12:44 PM   #8
Joe K
Joe K's Avatar
And, since this is a new experience, I'll tell you what you're likely to find:
1. The original headlight setup didn't include a "ground" between the bulb socket shells and the car frame. Modern restoration has (usually) MANY layers of paint which act as insulation between the parts. Many run an additional wire through the conduit along side the "feed wires" (tight fit possibly.) To act as ground.
2. The sockets are not made as original and instead of "pressed/formed paper" insulators, most modern replacement sockets have plastic insulators. For a while a lot of people were complaining about the heat of the bulbs (Maybe especially the 30-50) "melting" the plastic. Most more recent sockets have gotten past this problem.
3. Fords original "landing spot" for the wires was a plastic spacer piece (at Conduit ferrule) - many of which are either ill formed or melt from the heat of imperfect connection.
4. A corresponding problem is seen in the "bullet ends" formed onto the wiring harness and which SHOULD fit the ferrule plastic - but frequently don't and instead you get "intermittent" connection (I.e. lights go on and off) Solution here is to buy the aftermarket turned bullets and solder them onto the wire.
In a lot of different ways Ford didn't design well in the headlights. And modern "aftermarket" goods haven't helped.
There are "aftermarket sockets" available both for the main light and the auxiliary socket. These don't rely on the headlight shells which for these only offer "locating." But you wire your wiring harness DIRECTLY to the pig-tails. Gets away from the whole "bullet/spacer/contact connection" issue.
This same methodology can be used with original sockets - by which you retain the adjustment screw on the back of the headlight shell.
MANY struggle to get and retain a working headlight system.
Joe K
Shudda kept the horse.
Old 02-02-2025, 01:19 PM   #9
Steve Schmauch
The original Ford connectors at the headlight conduit ferrule were red or black bakelite substance, not plastic. They had raised letters indicating placement for red, yellow or green wires. The early 1928 connectors were different than late 1928 to 1931.
The engine pans served as a ground path to the frame, and many times these are missing on Model A's today, so the ground path is less effective and as Joe K says, many layers of paint inhibit a good ground system. With a properly restored vehicle you should be able to have the engine turned off, the lights turned on, and achieve a good strong horn sound!
Steve Schmauch is offline   Reply With Quote
Old 02-02-2025, 04:49 PM   #10
rfitzpatrick
With a properly restored vehicle you should be able to have the engine turned off, the lights turned on, and achieve a good strong horn sound![/QUOTE]
WOW! I'll never achieve that!!
TKS
rfitzpatrick is offline   Reply With Quote
Old 02-03-2025, 06:13 AM   #11
benbuilder
Thanks for all the help from everyone
Old 02-03-2025, 07:20 AM   #12
nkaminar
nkaminar's Avatar
Regarding the sockets at the headlight buckets: Many people run the wires to inside the buckets and then use individual pin type connectors there, including a ground wire. From the outside you cannot tell because the original stainless flexible conduit and connector bucket are used.
Old 02-03-2025, 10:12 AM   #13
Badpuppy
Another point, replace all the bulbs with BA15 base LEDs. Considerably less power drain, saves battery and gen.
Use a high lumen RED led for the brake light, will shine RED through the amber lens, much more recognizable to modern day butt sniffers.
Old 02-03-2025, 05:34 PM   #14
BButturff
BButturff's Avatar
Good point. I would add that in some states (MN for example), amber stop lights are not legal.
BButturff is offline   Reply With Quote
Old 02-04-2025, 05:51 PM   #15
Sunny the Model A
Sunny the Model A's Avatar
Be careful going with led's though. if your car is stock, it can blow led lights. My A burned out both led bulbs i installed, the brake light logolight bulb and the third brake light bulb. I went back to the incandescent bulbs, and they work just as well. I noticed at idle a noticeable flickering form the led's and for the record, the generator was on minimum charge. The incandescent bulbs do require turning up the generator at night, but that's a 5 second job. And if you burn out the incandescent bulbs, they are dirt cheap
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
