Old 01-29-2025, 06:19 AM   #1
flathead48
Default Headlights
Looking to improve the 6 volt headlights on my 48 automobile. Found this diagram on F B but lost as to the advantage of solenoid ?Attachment 559605
flathead48 is online now   Reply With Quote
Old 01-29-2025, 08:13 AM   #2
Don W/Norfolk
Default Re: Headlights
I believe the solenoid is shown to depict the source of a battery connection for headlight power. It does not perform any function in the headlight circuit. dw
I love this country; it's the damn idiots running the government I'm afraid of.
Don W/Norfolk is offline   Reply With Quote
Old 01-29-2025, 08:42 AM   #3
BW
I would look into LED's.
BW is offline   Reply With Quote
Old 01-29-2025, 09:06 AM   #4
Kube
Super Moderator
Kube's Avatar
I have installed a ground directly to the bucket (soldered) and then to the frame (soldered) in a way that no one could possibly see this additional wire. I do this for the head and the tail lamps. It makes a huge difference.
Old 01-29-2025, 09:29 AM   #5
flathead48
Thanks guys, Mike I did put a ground strap on the headlight buckets & taillights but trying to improve brightness when in cities or other times when RPMs are low. Thanks to all
Old 01-29-2025, 09:54 AM   #6
51woodie
51woodie's Avatar
Flathead48
I did this install on my '46 Coupe, after cleaning all the grounds and wiring connections, gave minimal improvement. The solenoid you referenced is the starter solenoid, and the yellow wire is connected to the battery side of the solenoid. There is no fuse shown in the yellow wire between the solenoid and the relays, which is not correct. The circuit needs fused protection. On my install, I left all the original disconnected wiring in place, and hid as best as possible, the new wiring and components. I now have nice bright headlights, and even get other cars "flashing" me when I forget to dim.
51woodie is offline   Reply With Quote
Old 01-29-2025, 11:17 AM   #7
flathead48
Thanks 51 woodie, I am just curious as to why use a solenoid , it seems u could go right from the battery to a 30 amp circuit breaker than finish the rest of the wiring. Thanks again to all.
Rick
Old 01-29-2025, 12:44 PM   #8
tubman
tubman's Avatar
Rick
If the solenoid is mounted in a favorable position (more direct wire runs) and a heavier gauge wire is used, there will be less resistance to the electrical flow and the lights, getting more voltage, will be brighter. This can be a help if there is a problem (corrosion, marginal connections, etc.) with the original wiring. In most cases, if the original wiring is in good shape, there will not a significant improvement. My '51, which was well-maintained and stored under good conditions previous to my ownership, has bright, white headlights on 6 volts.
Remember that under normal circumstances, the power for the headlights goes through the switch on the dash which adds length and extra connections to the circuit. A solenoid eliminates all of that.
Old 01-29-2025, 02:57 PM   #9
ford38v8
ford38v8's Avatar
Not to disagree with Tubman's reply, mine says the same thing with different wording:
With solenoids fed by 10 gauge wire, one each for high beam and low beam, mounted up front near the radiator, you'll get full battery voltage as close as practical to the headlights. Those solenoids being triggered by the original circuits which run through smaller gauge wire, headlight switch, and dimmer switch, will have too much built-in resistance for the headlights, but sufficient voltage to activate the solenoids.
Alan
Old 01-29-2025, 03:11 PM   #10
signsup
Ghere is a lot written on the G503 forum about this topic as most WWII vehicles were 6v and improving headlight and brake light visability is a concern. LED conversions, 12v upgrades, etc.
signsup is offline   Reply With Quote
Old 01-29-2025, 05:00 PM   #11
glennpm
glennpm's Avatar
This, excellent grounds and LEDs are the way to enlightenment :-)
Glenn
Old 01-29-2025, 05:01 PM   #12
flathead48
I appreciate the time all took to help out . Great bunch of guys.
Old 01-30-2025, 12:00 PM   #13
Kelly Burns
Kelly Burns's Avatar
This is a great and timely thread!
Kelly Burns
Kelly Burns is offline   Reply With Quote
Old 01-30-2025, 12:32 PM   #14
Drbrown
Drbrown's Avatar
As said and implied, grounding of headlights and using the most efficient supply i.e. the shortest routing of the headlight feed wires from starter solenoid thru a fuse to the lights. I used Relays a/k/a solenoids and heavy gauge wire on both the high and low beam circuits .... and much lighter gauge wire from the relays to the headlight switch. I also did same on a separate circuit for my Fog Lights.
Drbrown is offline   Reply With Quote
Old 02-01-2025, 07:00 AM   #15
ScubaChief60
ScubaChief60's Avatar
Can not resist adding to this thread.
I found that JEEP has LED headlights (12 V) that fit right into my 1935's headlight buckets perfectly... ( https://ca.doxmall.com/product/doxma...p-replacement/ )
I integrated a 6 v to 12 v converter ( https://www.amazon.com/Converter-Vol.../dp/B0D77XGGCK/ ) and the lights work perfectly.
Added benefit is that the JEEP Headlights have an integrated outer ring turn signal built right in too.
They work great and light up the road like a football field. Two years out I have no complaints.
ScubaChief60 is offline   Reply With Quote
Old 02-01-2025, 11:53 AM   #16
JayChicago
JayChicago's Avatar
Have not heard of that before. Surprised that they can fit in perfectly. Can you post a close picture of your headlight so we can see what it looks like from the outside?
Old 02-01-2025, 12:18 PM   #17
tubman
tubman's Avatar
I find that the voltage booster works so well is encouraging. The one he lists is 10 AMPS, which should be plenty with LED lights, and I imagine the increased current draw caused by the overhead of said converter is not significant.
Old 02-01-2025, 12:19 PM   #18
glennpm
glennpm's Avatar
ditto
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 02-01-2025, 06:13 PM   #19
ssffnomad
ssffnomad's Avatar
FH48, you may have to change your handle around her to
“Night Rider”
ssffnomad is offline   Reply With Quote
Old 02-05-2025, 06:21 AM   #20
ScubaChief60
Here is the Jeep headlight installed in my 1935 headlight bucket. It's LED and has integrated ring turn signal that flashes amber. It's 7 Inch diameter.
