#21 |
Great post! The timing is good too since I just replaced my solar panels on the roof for just this reason:
Solar panel #1 is a 20 Watt 12 V with a charge controller/maintainer to keep my diesel home generator battery at peak charge. Solar panel #2 is a 6 Watt 6 V with a charge controller/maintainer to keep my 1935's 6 volt battery at peak charge. Both seem to be working great. ![]() Found this as well: A battery maintainer is essentially a "smart" trickle charger, meaning it automatically monitors a battery's charge level and only provides a trickle charge when needed, preventing overcharging, while a basic trickle charger continuously charges at a low rate and may require manual disconnection once the battery is full; in short, a maintainer is designed to be left connected long-term to maintain a battery's charge, while a trickle charger is primarily used to slowly recharge a depleted battery that needs to be monitored. |
#22 |
I find the timers have a much better memory that I do, as well as being more consistent and reliable. And they don't go on vacation.
#23 | |
I'm uncomfortable leaving maintainers connected full time on cold storage vehicles/machines in the winter. I've learned over the years that occasionally checking battery voltages only requires about 24 hr. maintainer usage about once a month to restore voltage on several sealed/wet and Optima batteries. I would use timers as some have stated if I were away for extended periods of time, or at least store the battery(s) in a warmer location. Last edited by V8 Bob; 01-21-2025 at 12:54 PM. |
