Old 01-16-2025, 08:56 AM   #1
gabenac
Default looking for Harman Collins SU-6015 camshaft info
Hello,
Would any one have the specs for an Harman & Collins SU-6015 camshaft? Thanks in advance.
-Gabe Naccarato
gabenac is offline   Reply With Quote
Old 01-16-2025, 11:40 AM   #2
flatjack9
flatjack9's Avatar
Default Re: looking for Harman Collins SU-6015 camshaft info
IO - 26B, IC-64A, EO-59B, EC-19A. 270* duration on intake, 258* on exhaust. 45* overlap and .320 lift on both. Clearance: .011 intake and .013 exhaust
Old 01-16-2025, 01:27 PM   #3
Ol' Ron
Ol' Ron's Avatar
Latta cam for the street, might sound good tho!!!
Gramps
Old 01-16-2025, 03:05 PM   #4
gabenac
Thanks for the response guys! Would you consider this a full race or 3/4 race cam? Sorry I'm new to engine building, especially with the flathead! Thanks-Gabe
Old 01-16-2025, 07:36 PM   #5
birdball
birdball's Avatar
I had that cam in my sedan. 255” motor, 4” crank with 2x2. Ran great sounded amazing but not a ton of low end. I’ll try to post a video if I can figure it out…
**edit** my apologies! I miss read your question and you were asking about the 6015 cam- my post was for the 6014 cam. There is a video below anyway!
1932 2 door sedan/ Merc Flathead
1932 5W
1932 Roadster/ SCoT Flathead
1932 Roadster Cadillac power
birdball is offline   Reply With Quote
Old 01-16-2025, 07:54 PM   #6
birdball
birdball's Avatar
Here it is with 2” straight pipes:
https://youtube.com/shorts/erb_9JDdi0g?feature=shared
1932 5W
Old 01-16-2025, 09:42 PM   #7
flatjack9
flatjack9's Avatar
Sounds good.
Old 01-16-2025, 09:46 PM   #8
flatjack9
flatjack9's Avatar
So much depends on what your engine is. A cam will tend to be a lot tamer in a 276" engine as opposed to a 239".
Old 01-17-2025, 06:25 AM   #9
Tim Ayers
Very cool. Motor sounds great!
Tim Ayers is online now   Reply With Quote
Old 01-17-2025, 10:13 AM   #10
gabenac
Attachment 558849
Attachment 558850
Thanks for the response, that motor sounds great! I have a bone stock '37 21 stud flathead and would like to install a cam, dual carbs...basic hop up parts. I'm assuming this would be too radical of a camshaft?
Thanks Gabe
Old 01-17-2025, 06:43 PM   #11
38 coupe
38 coupe's Avatar
That is a lot of overlap for not much lift. I expect a cam with equal duration but a lot more lift would make more power, and idle about the same. Or you could get a cam with the same lift but less duration and get similar power but a nicer idle.
