Old 01-11-2025, 10:45 AM   #21
34fordy
34fordy's Avatar
Default Re: 8ba road draft tubes
You should be using a PCV system anyway.[/QUOTE]
What about the flatheads before the road draft tube was incorporated?
34fordy is online now   Reply With Quote
Old 01-11-2025, 11:29 AM   #22
tubman
tubman's Avatar
I am only familiar with 8BA's. I do believe I have seen this issue with earlier engines addressed on this forum several times. As I remember, one of these solutions had some plumbing under the intake manifold.
Old 01-11-2025, 11:57 AM   #23
MidState-Flathead
Joe B, If i understand your your question correctly, I am building a 8ba engine that will be put into a case ingersol garden tractor, with the tin work of an B allis chalmers tractor, there is a guy in northern wisc that built one of these tractor, he was very generous to help me with the plans on doing this project, anyway I had a carb builder from texas bulid me a 3x2 intake with stromberg 97s and what he did was machine in a tap into the passage of the casting leading to the draft tube and that tap will be used to recirculate the PVC gases, and the road draft tube I will find something like a solid rubber ball or something like that and jam it into the draft tube to make the tube non function, and still keep the look of the tube intact, I hope I was able to answer the question, I wish i could install pictures on the site and I have tried in the past and I failed, Hope this make sense
MidState-Flathead is offline   Reply With Quote
Old 01-11-2025, 02:05 PM   #24
Joe B.
Joe B.'s Avatar
Yes thanks.
thread killer
Joe B. is offline   Reply With Quote
Old 01-11-2025, 02:48 PM   #25
V8 Bob
V8 Bob's Avatar
What about the flatheads before the road draft tube was incorporated?[/QUOTE]
The first "road draft" system used on flathead V8s was introduced in 1935, exiting through a vent on the right front of the oil pan, and used until '49 when the external piping became production.
Flathead V8 PCV usage was actually started during W11 on some vehicles that had enclosed engines.
Old 04-11-2025, 09:17 PM   #26
The Kabar Racer - 8BA
V8 Bob, I have a '51 canadian 8BA from an F1 truck with the 2 piece draft tube. Im installing the enigine into a custom build 'pre-war' re-creation that Im building.
Where I plan to race it is on a dry lake bed circuit called Lake Perkolilli in Western Australia and the Draft tube 'gases' wont be a problem here, but if I race it on a road circuit then Ill probably need a catch can or other option...
My questions are: How can I keep it looking like the Draft Tube is still original, but run the gases thru a catch can somehow? and is there a performance issue doing this, or is there another easy option...
The Kabar Racer - 8BA is offline   Reply With Quote
Old 04-11-2025, 09:49 PM   #27
tubman
tubman's Avatar
Perhaps a better option would be to plug the end of the road draft tube, put an unobtrusive "tee" into it, and run a hose to a PCV valve exhausting into the intake manifold.
