I’m looking for a source for bolts for the rear of my 39 transmission. Specifically I am looking for the 6 rear bearing retainer, 4 clamshell to bearing retainer, and 2 clam shell bolts. If there is no source for a “kit” can someone tell me the sizes I need?
Thanks |
vanpeltsales.com has a ton of info and knowledge for free. thirdgenauto.com has knowledge and info, he also may have the bolts…….Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
Thank you
Bear in mind, the 4 bolts that hold the clamshell are fitted bolts.
the housing may well be worn, so new bolts will be loose, this will effect the U/joint and driveshaft concentricity with the gearbox output shaft. Lawrie |
Third Gen Auto in Tenn is also a possible source for the bolts. The 6 bolts to retain the rear bearing mount are drilled head for safety wire.
#6 | |
Super Moderator
