Old 01-08-2025, 04:45 PM   #1
BarryBrosRacing
Default 39 transmission bolt question
I’m looking for a source for bolts for the rear of my 39 transmission. Specifically I am looking for the 6 rear bearing retainer, 4 clamshell to bearing retainer, and 2 clam shell bolts. If there is no source for a “kit” can someone tell me the sizes I need?
Thanks
BarryBrosRacing is offline   Reply With Quote
Old 01-08-2025, 06:23 PM   #2
flatford8
flatford8's Avatar
Default Re: 39 transmission bolt question
vanpeltsales.com has a ton of info and knowledge for free. thirdgenauto.com has knowledge and info, he also may have the bolts…….Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 01-08-2025, 06:43 PM   #3
BarryBrosRacing
Thank you
Old 01-09-2025, 12:39 AM   #4
Lawrie
Lawrie's Avatar
Bear in mind, the 4 bolts that hold the clamshell are fitted bolts.
the housing may well be worn, so new bolts will be loose, this will effect the U/joint and driveshaft concentricity with the gearbox output shaft.
Lawrie
Old 01-09-2025, 11:59 AM   #5
Terry,OH
Terry,OH's Avatar
Third Gen Auto in Tenn is also a possible source for the bolts. The 6 bolts to retain the rear bearing mount are drilled head for safety wire.
Old 01-09-2025, 12:27 PM   #6
Kube
Super Moderator
Kube's Avatar
Thanks
I have them if you are still searching. Private message me.
Kube is online now   Reply With Quote
