Old 01-05-2025, 03:52 PM   #1
35fordPU
Default 1939 convertible door window removal
Need some help - trying to remove the passenger front door glass for replacement. Removed the panel, removed the crank stop but the window doesn't go low enough to remove the arms from the channel. Any help would be appreciated.
35fordPU is offline   Reply With Quote
Old 01-05-2025, 08:41 PM   #2
v8fordman
v8fordman's Avatar
Default Re: 1939 convertible door window removal
I believe there are two stops on the regulator. Check to see that you removed the correct one. I just did this on my ‘37.
v8fordman is offline   Reply With Quote
Old 01-06-2025, 10:19 AM   #3
glennpm
glennpm's Avatar
There is usually a screw in the bottom of the channel that must be removed.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 01-06-2025, 06:35 PM   #4
35fordPU
Thanks guys, I’ll check tomorrow. Appreciate the responses.
Old 01-06-2025, 06:41 PM   #5
Kube
Super Moderator
Kube's Avatar
You must remove the screws that hold the regulator in place. Lower the entire "thing" to the bottom of the door.
Perhaps I shouldn't say "you must". However, I have done MANY and that method has worked well for me.
