Okay well I be able to reuse this switch I am rewiring the whole car using one of those hot rod 12 circuit type of fuse panels I would like to reuse this I don't want to take nothing apart until I ask a couple of questions is there some type of diagram that I could use this if I take it apart will I be able to rewire it has anybody had any experience with this or do they sell a new unit thanks guys
Vanpelt Sales has wiring diagrams on their website in Parts Drawings/Electrical. I'm using them to rewire my 35.
Awesome I will look them up thanks
It is made so it can be taken apart. The end where the wires exit rotates a bit and then can be lifted straight off the body. Suggest some lube where the two pieces meet. Inside is a black plastic plate with the electrical terminals attached. I would guess your going to have to unsolder or drill holes in the terminals so wires can be attached and soldered securely in place.
Ok
Yes i have it soaking out back Will pull apart later on Looks like some places sell the wiring for it Would be sweet if it all works out |
#6 | |
Our cure was to dig out an old harness, salvage the terminals, and reuse the original plates. |
Mine is pretty nice inside
Need to get that diagram now and see what's what and splice wires.. |
Here we go
