Old 01-04-2025, 09:14 AM   #7
Talkwrench
Talkwrench's Avatar
Default Re: Right rear axle seal
As Kube said, I might be difficult to see the colours of the gaskets if they've been in for a long time. Be very careful of removing those diff seals . If they are originals they will come out easier, if newer ones they can jam in and what happens is they'll start to break apart as you're smacking at them to get them out and in the end you'll be left with the outside of the seal stuck in there.. Then a special tool needs to be made to cut them out. When installing I take that red paint off around the outside of the seal and put some anti-seize on
