I have Period Correct USED gauges (oil pressure, amp, fuel) Is there a way to check them prior to installation?
Do you want to fully test them or just check for movement?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
I would like to fully test them....
You'll need a 6v power source. I tested my fuel gauge by simply wiring the sender, gauge, and power with the sender out of the tank. Moving the sender arm should move the gauge. The amp meter can also just be wired up before installation to check it.
I'm not smart enough to know about oil pressure gauge testing.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it Last edited by FortyNiner; 12-18-2024 at 08:05 AM. |
#5 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Just don't ask how I check the temp gauge (at 98.6)
Back down to the shop after that one...
OK, so I know it's kinda gross thinking about holding that brass sending unit under my tongue like having your temperature taken at the doctor's office.... Heck, it'd have to be in there for at least ten minutes and I don't think I could go that long without talking! Where's the 'roll eyes' imogee anyhow? What?
