Old 11-24-2024, 08:16 PM   #1
Vette1345
Default 39 Sedan Delivery
Screwless window garnish mounding. How do the clips work? I have new clips but if in install them the moulding won’t button hook in. Withe the clips off I put the top in first then bottom will go in. I did not take apart so I have no idea where the five clips go. Any help will be appreciated.
Carl
Vette1345 is offline   Reply With Quote
Old 11-25-2024, 05:49 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 39 Sedan Delivery
1939 Ford Sedan Delivery
Old 11-25-2024, 09:30 AM   #3
terry
could you show a pic of the clips? The ones i bought for my 36 were ever so slightly different and I had to go with the old ones. terry
terry is offline   Reply With Quote
Old 11-25-2024, 09:49 AM   #4
Vette1345
Old and new clips
Thanks Terry
Old 11-25-2024, 04:55 PM   #5
terry
Entirely different from mine. Sorry, but I can't help. Hope someone will come on that
can help you out. terry
Old 11-26-2024, 10:17 AM   #6
marko39
I bought new ones for my 39 deluxe and found I really didn’t need them to hold the moulding in.
marko39 is offline   Reply With Quote
Old 11-26-2024, 02:08 PM   #7
SUHRsc
SUHRsc's Avatar
I'm sorry I don't have any input, I took mine off and back on but don't recall how they attached. Shouldn't be specific to sedan delivery ...In any case. Can you post some photos of your 39? I have one also, they're fairly rare so nice to see others..
-WANTED-
CYLINDER HEADS
77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS
SUHRsc is offline   Reply With Quote
Old 11-26-2024, 03:11 PM   #8
tubman
tubman's Avatar
Did they make a DeLuxe sedan delivery in '39? That would be pretty much my ideal vehicle.
Old 11-26-2024, 03:30 PM   #9
rockfla
rockfla's Avatar
I just recently found out they made a hand full of 38 "standard" Sedan Deliveries. I'm gonna stick my neck out and say NO to a 39 Deluxe sedan Delivery, the closest to that grill style, I think, would be a 41 Sedan Delivery NO??.....I would have said no about a 38 standard too......SO hell, what do I know?
Old 11-27-2024, 06:18 PM   #10
Vette1345
Old 11-29-2024, 05:07 AM   #11
SUHRsc
SUHRsc's Avatar
I could be wrong but I believe in 37\8 they did actually offer a "deluxe" sedan delivery but the 38 still features the standard type sheet metal. Just upgraded with a chrome windshield frame and maybe a few other options. As far as I'm aware the 39 did not have this option. 39 was a pretty low production year with only around 3000 produced.
-WANTED-
CYLINDER HEADS
Old 11-29-2024, 05:09 AM   #12
SUHRsc
SUHRsc's Avatar
Looks like a fairly solid vehicle from that angle. Good luck getting it together. If you need any photos or anything, mine is mostly as it was parked in 1948.
Originally Posted by Vette1345 View Post
-WANTED-
CYLINDER HEADS
Old 11-29-2024, 12:55 PM   #13
Vette1345
I got it out of Ca. but still had to replace all the floors. The rest of it had spot rust that I cut out for new metal. I am resto moving it keeping 98% original but will have all modern running gear underneath. I copied the pictured back interior you posted. I had just built all new panels out of 1/8 in. abs plastic. Mine was gutted when I got it. All the panels are ar the upholster now.
Carl
