Old 11-04-2024, 03:10 PM   #1
flathead 53
Default distributor on 53 f-100
I converted my 53 f-100 with 51 merc flathead to twelve volts , I also installed A pertronix distributor , should the vacuum advance from the distributor be hooked up to the manifold vacuum or the port on the holley 94 carb.
flathead 53 is offline   Reply With Quote
