Old 10-28-2024, 10:54 AM   #1
3twinridges
3twinridges's Avatar
Default 8BA stroker kit
Machine shop called me this am to tell me the 4” crank I brought them was cracked on a main journal. Time for a stroker kit.
This is a stock engine, stock carb/ignition. How big of a stroke can I go with? I want to go with at least 4 1/8 stroke but would to go 4.25 if possible, thoughts?
JB
3twinridges is offline   Reply With Quote
Old 10-28-2024, 01:40 PM   #2
3twinridges
Default Re: 8BA stroker kit
4” crank on the way. I just didn’t like having to bore this good block out to 3 5/16 for the 4 1/8 and 4 1/4 stroke. 4” is plenty
JB
Old 10-28-2024, 02:27 PM   #3
GB SISSON
GB SISSON's Avatar
Good choice. Did you order a brand new 4" crank?
Old 10-28-2024, 02:31 PM   #4
3twinridges
I did.
JB
Old 10-29-2024, 05:25 AM   #5
KiWinUS
KiWinUS's Avatar
Just an FYI. you don’t need to bore block just because you install a 4 1/8” or 4 1/4” crankshaft. Either would have been a great addition and additional c.i.
Old 10-29-2024, 05:31 AM   #6
Tim Ayers
I was wondering the same. I think because the stroker kits usually come with pistons, rods, etc. as part of the "kit".
Old 10-29-2024, 05:55 AM   #7
38 coupe
38 coupe's Avatar
If anyone knows of affordable (same price or very close to 4" stroke) cast pistons for +0.060 or smaller overbore and a 4 1/8" stroke please let me know.
All the available 4 1/8" and 4 1/4" stroke pistons I find these days are +0.125 or larger over bore and many are forged. Unless building a hot rod engine these don't make sense to me. Given piston availability the 4" stroke crank makes sense to me.
Old 10-29-2024, 07:03 AM   #8
Tim Ayers
38 Coupe,
Have you called Egge? I'm pretty sure they'll do any size. Ross will as well, but I'd assume they would be out of your budget range judging by what you said in your post.
Old 10-29-2024, 08:16 AM   #9
3twinridges
When I talked to H&H yesterday it seemed like a 4.125 stoke was not in the cards without a 5/16 bore. But I see a 4.125 scat with standard size rod journals and Ross makes a 4.125 stroke 60 over piston so not sure why that combo will not work with standard rods. I am going to call H&H this morning and dig around a little more.
JB
Old 10-29-2024, 08:23 AM   #10
Tim Ayers
JB
This went from being a stock build to a stroker motor real quick and I love it! LOL!
Old 10-29-2024, 10:57 AM   #11
tubman
tubman's Avatar
I would not build an 8BA without a 3 5/16 bore. I have done 3 of them and the machinist said they all would have gone more. ("OL' Ron" has mentioned 3 7/16"+ engines). To be fair, I did have to have one cylinder sleeved because of a casting flaw that caused a pit in the wall. The machinist said we could run it as is, but a sleeve would be good insurance.
The pistons cost about the same and like they say, "There is no replacement for displacement".
Old 10-29-2024, 11:03 AM   #12
Tim Ayers
Exactly!
Old 10-29-2024, 12:19 PM   #13
Bored&Stroked
Bored&Stroked's Avatar
Yes - I would bore to 3 5/16 as well and if you're ordering a kit (depending on the rods you'll be using), I'd go to 4.125 or 4.250 stroke. There is nothing like the additional torque and cubic inches to bring a broader smile to your face! LOL
Here is the kit I'd order:
https://www.scatcrankshafts.com/product/1-94617bi/
Old 10-29-2024, 12:26 PM   #14
tubman
tubman's Avatar
These are not modern castings that are "done" at .060" over. Henry made 'em to last.
Old 10-29-2024, 01:27 PM   #15
3twinridges
The problem with the 4.125 crank is the lead time on 4.125 60 over pistons. Well over 4 weeks to have them built. 4” 60 over are much more readily available.
JB
Old 10-29-2024, 03:39 PM   #16
19Fordy
19Fordy's Avatar
Gosh, I remember when I bought a complete 296 stroker kit with floating rod bearings and Jahn's pistons from Crankshaft Co. in CA in 1967 for about $500. Then it cost me a whopping $5 per hole to have it bored. My pay back then was $1.15 per hour. Took a lot of "saving up".
Old 10-29-2024, 03:39 PM   #17
Ggmac
3twinridges , I sent you a email or pm , I forgot what I clicked on . Its about a motor I have that I’ll not be needing now . It sounds exactly like the one you want to build .
Gary
Old 10-29-2024, 04:33 PM   #18
3twinridges
I am going stay with the 4”. Machine shop talked me out of a 4 1/8. They were afraid the extra stroke would put strain on the bearing caps and introduce more wear than a 4” for not much gain.
Old 10-29-2024, 04:35 PM   #19
3twinridges
Gary
Appreciate it but the purpose of the build is to introduce the kids to an iconic engine build. I want them to see one get put together and help me. Again appreciate the offer. Follow along as we have fun with it!
JB
Old 10-29-2024, 05:03 PM   #20
Tim Ayers
For what you are looking to do, makes sense.
While you are in there, may I suggest cleaning up the exhaust and intake ports?
You can do this with sand paper rolls and a long arbor. The little effort/time it would take, it would make a difference and it will sound a little more like a hot rod flathead if you can get it to breathe better in & out.
