Old 09-12-2024, 12:15 PM   #1
47topless
47topless's Avatar
Default 2 blade fan "bullet-proof?"
My '31 Victoria has the stock, two blade fan. I am aware of all the inherent potential tragedy, regarding these fans, and their propensity to come apart and turn into flying shrapnel while the engine is running. Good (new), two blade fans, seem hard to find. Is there a way to "bullet-proof" this original fan, much the same way as you can "bullet-proof" a Columbia overdrive, and make this safe to use?
It would be nice to keep this original fan.
Thank you,
Phil
47topless is offline   Reply With Quote
Old 09-12-2024, 12:42 PM   #2
Flathead
Flathead's Avatar
Default Re: 2 blade fan "bullet-proof?"
I would say no to the modifications and just wait (or find) an aluminum replacement.
Flathead is online now   Reply With Quote
Old 09-12-2024, 01:15 PM   #3
Brentwood Bob
The Restorer has an article that addresses this.
Brentwood Bob is offline   Reply With Quote
Old 09-12-2024, 01:47 PM   #4
JayJay
47 - I believe Snyders actually makes the aluminum two-blade fan. Tam's says they are out of stock until October, other vendors simply say "out of stock". If you want one you might contact your favorite vendor and see if you can get on a waiting list. I did that a couple of years ago when those fans were similarly out of stock. As soon as Bert's got an order in they shipped me two per my standing request.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is online now   Reply With Quote
Old 09-12-2024, 03:31 PM   #5
WHN
Take it off your car. It’s a tragedy waiting to happen.
Order the aluminum two blade and wait for delivery.
I have had an original fail. It’s not pretty. Your engine compartment could take a real beating or worse.
Please do not take a chance.
Enjoy.
Old 09-12-2024, 04:05 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
There are 2 types of original fans,the design was changed late in 31 ,the blade tips are a single layer on the later one,the metal is much thicker too.
the later ones don’t seem to crack at the hub—-
I have seen plastic blades break and go though hoods too
Old 09-12-2024, 07:56 PM   #7
700rpm
700rpm's Avatar
Enjoy.
Fully Agree! - Horton
Ray Horton, Portland, OR
Old 09-13-2024, 02:29 PM   #8
47topless
47topless's Avatar
OK!!!!! Out with the old, in with the new. A new aluminum two blade.
Thanks for your responses.
Old 09-13-2024, 05:54 PM   #9
ModelA29
ModelA29's Avatar
It's going to fail. It's a crap shoot when. If you want to run it because it's a fine point car at least pull it off annually and magnaflux or dye check it for cracks.
ModelA29 is offline   Reply With Quote
Old 09-14-2024, 07:17 AM   #10
Fullraceflathead
Fullraceflathead's Avatar
There is a very good reason why the ford dealerships replace the 2 bladed vans with the 4 bladed fans anytime they have the opportunity it was definitely a safety issue even back then!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-14-2024, 09:47 AM   #11
gdmn852
gdmn852's Avatar
Hello, true , those old 2 blades were a problem even then, recalled back in 1970,s with my 1st Model A , “old timers “ telling me stores of broken fan blades. The only problem I had with the new blades is sometimes you have to remove a bit of water pump “snout “ as the new pulley area is thicker being cast . Also currently on A I am restoring, the hood side panel has a dent from inside out , probably from broken fan at one time.
gdmn852 is offline   Reply With Quote
Old 09-14-2024, 09:56 AM   #12
Tom F OHIO
Tom F OHIO's Avatar
Had a guy lose his radiator and hood on one of our club meets. Flat bed here we come.
Tom F OHIO is offline   Reply With Quote
Old 09-14-2024, 10:10 AM   #13
old31
I have a friend that wanted me to change his water pump. He said everything else was perfect, so dont spend any more money! The car was truly a+ restoration when it was done with this fan. When I took off the fan off this is what i found.
How long do you think he had? 1 fan revolution, 50-100?
old31 is offline   Reply With Quote
Old 09-14-2024, 10:11 AM   #14
old31
delete
Old 09-14-2024, 10:24 AM   #15
nkaminar
nkaminar's Avatar
The original two-bladed fans are fine, as long as you don't run your engine.
Old 09-14-2024, 05:21 PM   #16
Flathead
Flathead's Avatar
I have to admit you can't argue with that logic!
Old 09-14-2024, 07:22 PM   #17
Clem Clement
Clem Clement's Avatar
Why not replace the fan with a moder safe on and enter the original fan as part of the tool kit? Safety first.
Old 09-15-2024, 10:41 AM   #18
Fullraceflathead
In today's world considering they're almost 100 years old the original ford 2 bladed fans should be considered for display purposes only!!!
-Henry Ford
1941 Willy's Pickup
Old 09-15-2024, 03:40 PM   #19
Ivan in southeast va.
Ivan in southeast va.'s Avatar
This is where original fan blades belong.
Ivan in southeast va. is offline   Reply With Quote
Old 09-15-2024, 05:20 PM   #20
Synchro909
Synchro909's Avatar
I have had trouble with that also. I make my own long life, leakless water pumps that work wonderfully well but I can't use one of those fans with them. Any other fan works though.
I don't like reducing the nose of the pump because it loses strength right where I put a ball bearing as part of my conversion.
Are you listening, Snyders?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
