Old 09-07-2024, 03:36 PM   #1
std1940
std1940's Avatar
Default 1940 Ford Coupe wheel alignment and steering wheel centering
I had a front end wheel alignment on my 1940 Coupe .
Now my steering wheel is not centered as it was before?
I had the drag link tie rod replaced as part of the alignment.
My front end is totally stock.
What needs to be done to center the steering wheel to the right clock position?
It is driving me crazy!
Thanks Tom.
std1940 is offline   Reply With Quote
Old 09-07-2024, 03:44 PM   #2
V8 Bob
V8 Bob's Avatar
Default Re: 1940 Ford Coupe wheel alignment and steering wheel centering
The alignment shop should have secured the centered steering wheel before any work was started. Have them re-do the alignment, or find another shop.
Old 09-07-2024, 03:55 PM   #3
glennpm
glennpm's Avatar
Instructions in the attached pdf.
Glenn
File Type: pdf Adjusting Steering Wheel Position on 1940 Ford.pdf (160.7 KB, 59 views)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 09-07-2024, 04:03 PM   #4
19Fordy
19Fordy's Avatar
std40: Along with glennpm's excellent info. here's a little more:
https://www.fordbarn.com/forum/showt...steering+wheel
Do a Fordbarn SEARCH on "How to center 1940 Ford steering wheel" and even more appears.
Old 09-07-2024, 04:14 PM   #5
ford38v8
ford38v8's Avatar
You had it done? The pimple faced trainee likely didn’t align your wheels per Ford specs if he didn’t even center the steering wheel. Don’t bother going back there, as the owner apparently relies on customer complaints to educate his flunkies.
Alan
Old 09-10-2024, 08:29 AM   #6
std1940
std1940's Avatar
Glenn
What you are showing me makes perfect sense but my drag link does not have a rotating connecting sleeve.
The passenger side ( right) has a tie rod that screws into the fixture.
The drivers side (left) has a tie rod that does not screw into the fixture .
It is made as part of the fixture.
How do I make the correct adustment with the tie rod with out the adustable connecting sleeve?
Thanks Tom.
Old 09-10-2024, 08:38 AM   #7
Zax40
Zax40's Avatar
Thanks Tom.
That does not sound right. Who did you buy your parts from and can you take pics? I just replaced mine two weeks ago so it's still fresh in my mind. The non adjustable end should be on the right (passenger) side and the adjustable side should be on the left (driver) side. It should have a sleeve so it can be adjusted without disconnecting it.
Zax40 is offline   Reply With Quote
Old 09-10-2024, 08:53 AM   #8
std1940
std1940's Avatar
This is what I got.
This pictures is from one of Kubes posts.
File Type: jpeg 16AB1B9B-D6D9-4646-92EA-4593EDDE581B.jpeg (29.0 KB, 38 views)
Old 09-10-2024, 09:00 AM   #9
glennpm
glennpm's Avatar
Incorrect post
Rumble Seat’s Notes
Old 09-10-2024, 09:02 AM   #10
glennpm
glennpm's Avatar
Incorrect post
Rumble Seat’s Notes
Old 09-10-2024, 09:03 AM   #11
glennpm
glennpm's Avatar
My bad on the drag link.
File Type: pdf Adjusting Steering Wheel Position on 1940 Ford.pdf (160.7 KB, 20 views)
Old 09-10-2024, 09:17 AM   #12
Zax40
Zax40's Avatar
You adjust the Tie Rod and NOT the drag link which is the bottom one in Kube's photo.
The tie rod adjustment is for setting toe, the drag link adjustment is for centering the steering wheel
Old 09-10-2024, 09:19 AM   #13
Zax40
Zax40's Avatar
I bought my drag link from Joe's and it has the adjuster sleeve.
https://www.joesantiqueauto.com/drag-link-11y-3306
Old 09-10-2024, 09:20 AM   #14
glennpm
glennpm's Avatar
Yes I blew it. Working on my car, listening to wife and not focused :-(
Rumble Seat’s Notes
Old 09-10-2024, 03:54 PM   #15
std1940
std1940's Avatar
Zax40
I see that the one that Joes sells has the adjusting sleeve but the one I have has nothing wrong with it and is correct according to Kubes pictures.
So how do center the steering wheel with the correct drag link as pictured?
THanks Tom.
Old 09-10-2024, 04:01 PM   #16
Mart
Mart's Avatar
If you do not have a separate sleeve you can still adjust it. Break the drag link end at the spindle and turn it in or out to adjust.
Without a separate sleeve you are limited to adjustments where the minimum increment of adjustment is one thread pitch.
Old 09-10-2024, 04:10 PM   #17
Kube
Super Moderator
Kube's Avatar
What he has IS correct. The adjustable sleeve type was a service part, not the same as what was installed at the factory.
He will need to remove the end that has the adjustable end, turn it and see if he turned it enough to center the steering wheel or too much.
Old 09-10-2024, 04:13 PM   #18
Kube
Super Moderator
Kube's Avatar
That link you bought fits and works. It is NOT correct.
The link in the photos is correct.
Old 09-10-2024, 05:08 PM   #19
std1940
std1940's Avatar
Kube, Mike,
I have tried turning in both directions and can’t get the steering wheel in the sweet spot.
You are limited because of spindle orientation .
Turning the tie rod to where the steering would be centered makes it impossible to attach to spindle.
Thanks Tom.
Old 09-11-2024, 08:41 AM   #20
kartrae7
kartrae7's Avatar
Unhook drag link. Center steering wheel. Turn drag link end till it drops in hole. If wheels not exactly where you want it adjust again till it is. Mike
kartrae7 is offline   Reply With Quote
