Old 09-02-2024, 01:39 PM   #3
dsglass95
Default Re: First time poster... with a couple of questions.
Thanks for the reply. I have confirmed that there is spark on the font 2 cylinders, and the spark is strong there. I haven't done each cylinder separately though. Will have to try that. I have tried starting fluid, and brake clean, but it wouldn't event try on that. I have had the best luck using 2 stroke gas mix, but mostly all it will do is start, stumble a bit then die. After that, all It will do is hit on what I believe is the strongest of the cylinders. I will take a look to make sure all the plugs are getting spark, and if not, dig into the distributor.
dsglass95 is offline   Reply With Quote
