Working with a museum in another state that is trying to put an AA trans. back together. Their question is how the rear bearing retainer parts are assembled.
Was wondering which way the inner plate is installed. Any pictures available? Thanks for any help. |
Glass beaded my motor mounts to get them ready for paint on my ‘29 Tudor. Still have 4 months to wait for my engine and trans to come back from the Rebuild Shop. Tomorrow I will be dropping off my radiator for a cleaning / repair / paint at the radiator shop.
I think you posted wrong.
Here are a couple of pictures that might be of use.....this transmission was in an A ccpu so the rear retainer has been altered, but it might give you a starting point
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
John in warm sunny Suffolk County England . |
How to post pictures here?
Click on "Go advanced", click on the paper clip icon.
3585978053417895733.jpg Hopefully these are the pics of the parts. Need correct sequence of parts. Does this housing have grease zerk like the A? If not does it have a specific way to be mounted? |
You only use one of those parts, depends on what coupling shaft you have. If you have a u-joint on the trans output you use the large bearing retainer. If you have the splined coupling shaft you use
the small stamped retainer. |
I have a 4 sp. at home I can take pics of when I get home.
Mike
