I have a flywheel off of an 8RT to replace my 8CM flywheel. This will allow me to run the readily available long style clutch. Will the 8CM starter and starter plate work with the 8RT flywheel? If not, exactly what do I need?
I am pretty sure the answer is "Yes".
Check this out: https://www.bing.com/search?q=do+194...ANAB01&PC=HCTS |
#3 | |
The 8CM flywheel will allow a readily available diaphragm pressure plate, either aftermarket or from a clutch re-builder. |
I found the easiest and cheapest way was just to take my 8cm flywheel to a machine shop and have it re-drilled for the ford clutch. Tim
If your 8CM is from a 49, 50, or early 51 Mercury the pressure plate already works with the larger throw out bearing and no need to change. If you have the later pressure plate then I agree with Tim, just redrill the flywheel to match the new pressure plate. Any competent automotive machine shop should be able to do this without problem, and surface the clutch face for you too.
